Why do they make auto transmissions do this?
Old Mar 4, 2005 | 08:33 AM
  #16
falchulk's Avatar
Re: Why do they make auto transmissions do this?
An aftermarket converter should have a higher stall speed. That means the rpms should have to go higher to produce the same roll as a stock converter. Depending on the aftermarket converter, your car may actually roll backwards on a hill without gas.
Old Mar 4, 2005 | 08:46 AM
  #17
NikiVee's Avatar
Originally Posted by neurotictim
Okay, so it is normal to have to apply light brake pressure...
Except my Z28 will roll at 25 or 30, once I get it there, without having to touch the brakes... And I have to virtually stand on the brake to keep it from moving at a light...
I bought the car with a bunch of mods done, is it possible that an aftermarket torque converter is causing this? I know my previous car, a 96 RS, didn't do that.
All I know for sure that's been done to the car is the supercharger, headers, exhaust, and the rear end has been built...
Where is your idle set at? A high idle speed will allow the car to push harder against the torque converter.
Is you aftermarkert converter a tight or loose one?
Old Mar 4, 2005 | 10:46 AM
  #18
WJH'sFormula's Avatar
I say it's one more reason not to buy a car with a slushbox...
BOOO....autos....BOOO!!!
Old Mar 5, 2005 | 12:37 AM
  #19
neurotictim's Avatar
Like I said, I bought the car with a bunch of mods already done, but the only ones I know for sure about are the obvious ones - basically meaning I don't know if it has an aftermarket stall converter or not...
I need to get the car tuned - it does idle high, so maybe changing that will fix it... I thought it was normal for a forced induction car to idle above 1K.
We'll see.
Old Mar 7, 2005 | 07:41 AM
  #20
falchulk's Avatar
We'll see.
I have never heard that forced inductiuon cars idle high. Especialy v8's. I had a friend with a turbo mustang that idled at 750.
Old Mar 7, 2005 | 06:16 PM
  #21
JEDCamino's Avatar
My brother's '85 Chevy truck used to idle extremely fast (very screwed up Quadrajet). He could literally go 50 mph without touching the gas. One time we were at a red light and his truck started doing a brake stand on it's own.
Old Mar 8, 2005 | 04:37 AM
  #22
How's that do with gas mileage, and doesn't that make you launch pretty hard all the time?
I will eventually get an aftermarket converter, but I don't want to feel like I'm at the track every time I leave a light...
Old Mar 8, 2005 | 10:41 AM
  #23
falchulk's Avatar
No, you launch like a civic if you dont get the rpms too high. If you floor it you will launch VERY hard.
Old Mar 8, 2005 | 09:02 PM
  #24
JEDCamino's Avatar
I've got a 3500 and it can definitely be an annoyance around town sometimes. I have to give it nearly half throttle to keep up with other traffic, so it would probably suck in a daily driver. I had a 2500 before this one and it just felt like the stock converter.
Old Mar 9, 2005 | 01:11 PM
  #25
TurboDropTop's Avatar
With my TSi if I'm going about 5mph in 1st gear It will just keep going forever without touching the gas. Nice for rush hour traffic.
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
rideordie
Nov 5, 2019 04:52 PM
ChrisFrez
Jan 11, 2015 03:47 PM
Sarahrope64
Nov 27, 2014 11:17 AM
