Why Do Speedometers Go To 160MPH?
Old Oct 24, 2008 | 08:07 AM
  #61
onebadponcho's Avatar
Originally Posted by Z28Wilson
According to this site, the 1986 IROC cars were the first of the 3rd Gens to get higher limit speedometers, later in the model year that year.
http://www.iroczone.com/techartspottersguide.html
I pretty clearly remember that my '86 had the 145 mph one.
That website is a good read. Thanks.
I really miss the 3rd gens I had.
Old Oct 24, 2008 | 08:47 AM
  #62
Eric Bryant's Avatar
Originally Posted by Tokuzumi
It showed a fairly accurate rpm when cruising, but when he got on it, it would just throw the needle to the right in a hurry, and not because it was fast (305 TPI).
My Impala's tach does the same thing - if I hold a steady RPM, it's fine, but if the engine speed changes quickly, then the tach spikes to its maximum reading and stays there for a second or two. It's rather annoying at the drag strip
Old Oct 24, 2008 | 10:13 AM
  #63
hey01's Avatar
Because the tachs in those cars were poor indicators of engine speed, at best. My friend's 91 would rev all the way to 7K, according to his tach. It showed a fairly accurate rpm when cruising, but when he got on it, it would just throw the needle to the right in a hurry, and not because it was fast (305 TPI).
I think thats a 305 thing, monte SS does the same thing.. revs....revs....revs...holy **** the needle is going past 7 to an imaginary 8.
Old Oct 24, 2008 | 04:38 PM
  #64
AdioSS's Avatar
West South Central Moderator
I never noticed that in mine or my dad's? Your engine probably makes as much power as both of those engines together though.
Maybe that is just the tires breaking loose from too much horsepower!
Old Oct 24, 2008 | 04:50 PM
  #65
muckz's Avatar
Originally Posted by R377
Not if the G8 is any indication ... it has the same numbers in Canada as the US cars (goes to 180). North American-built GM cars change their numbers depending on where they're sold, but I'm not sure why the Aussie ones don't.
You mean to tell me that G8 has a speedometer that goes to only 180 km/h? Wow. That is a first.
Is that true of GT as well?
What is G8's speed governor set at?
Old Oct 25, 2008 | 10:11 AM
  #66
mdenz3's Avatar
There is a write-up on thirdgen.org on how to fix that. One of the resistors in the instrument cluster goes bad and causes high than accurate reading. Before I did it the tach was at 7k at idle.
Old Oct 25, 2008 | 02:37 PM
  #67
JakeRobb's Avatar
Super Moderator
I knew a guy in high school that thought that the highest number on the speedometer in a car was a reliable indication of that car's top speed. Seriously, you could have put a 250mph speedometer in an Escort and he would have believed it could go that fast.
Old Oct 25, 2008 | 03:06 PM
  #68
formula79's Avatar
Originally Posted by guionM
The governor in your GTO is set at 155mph.
There are ways to fix that
Making a speedometer go no higher than 85mph to slow people down is ignorant. If you put the same amount of food in smaller packaging people don't eat less. It's just a pansy way of trying to control people without using speed limiters..which is what treehuggers really want.
Old Nov 12, 2008 | 02:59 PM
  #69
Gord's Green Z28's Avatar
The 85 mph speedometer rule was enacted by Joan Claybrook as head of the NHTSA that started in 1980.
Although the law took effect in 1980, manufacturers got a jump on it and started putting in 85 mph speedos back in '76-'77.
I always figured it was because of the low HP numbers in cars back then. 1981 Corvette. The fastest model that GM offered....190 HP, 3 speed automatic.
The 85 mph limit on speedometers might be why the 84-89 Corvettes had the bar chart that read up to 85 mph. But would give an actual digital readout of your top speed as fast as you wanted to go.
Originally Posted by graham
I have a much better question.... why does a Chevy 305 tach need to go to 7-grand!?!
Why does my GTA go to 8000 RPM? I don't know anybody who's going that high more than once.
I agree on Euro cars having crazy speedometers. I remember looking at Jettas and Passats 10 years ago and seeing 240 and 260 gauges. Dream on!
I've had the weirdest luck with speedometers over the years:
89 GTA 240 km....won't get there because the automatic transmission won't go full throttle in 4th
94 Z28 180 km....governor model. A 2.73 geared car that maxed out at 4000 RPM in 3rd gear. Booooo. That got changed. It still irks me that the V6 models had faster speedometers (200 km)
94 Trans Am 150 mph..... 3.23 geared auto. No problems with speedometer, except I lived in Canada.
87 Sunbird GT 140 km....pedal to the metal in 5th gear it would do 160-165 (going off the tach RPM)
The newer Vettes make sense for the most part. 200 gauges in the USA, 300 gauges in Canada. Trouble is when you switch countries with them, all of a sudden you have a 200 km gauge or a 300 mph gauge. (unless you want to keep the other measurement displayed).
Old Nov 12, 2008 | 07:46 PM
  #70
93Phoenix's Avatar
Originally Posted by detltu
The highway speed back in the day was 55 and it was determined that that was them most efficient speed to drive fuel economy wise.
A buddy of mine claims thats there because that's when the car should be taken out of drive and into overdrive.
LazyLemming
Aug 29, 2015 07:36 PM
nosliw
Apr 27, 2015 04:01 PM
mattstrike
Mar 12, 2015 10:12 PM
red
Apr 6, 2003 08:02 PM
Michael Ozorowsky
Oct 2, 2002 01:58 PM
