Video: Springless engine
Old Feb 2, 2010 | 03:47 AM
SSbaby's Avatar
Stolen from another forum...
OHC
OHV
A lot of tappet noise with the covers removed. But I wonder what long term durability is like?
Cylinder compression shows 170psi on the OHC engine... seems kinda low?
PS Sorry if a re-post!
Old Feb 2, 2010 | 06:14 AM
transAMdriv3r's Avatar
wow thats neat ! I'm curious to what the durability is like too.
Old Feb 2, 2010 | 06:36 AM
SSbaby's Avatar
Actually, this technology is nothing new (I found out after I posted) as Ducati use the Desmodromic valve system on their motorcycles today. In 1955, Mercedes used the technology on some of their racecars.
It looks cool anyway, even if it doesn't quite overcome the capabilities of modern valve springs.
Old Feb 2, 2010 | 09:40 AM
HAZ-Matt's Avatar
I'm still waiting for the electromagnetic valves
Old Feb 2, 2010 | 12:29 PM
99SilverSS's Avatar
People into motorcycles know of this system because as you mentioned Ducati has utilized it for a long time.
I've often wondered why more automotive or even other motorcycle manufacturers have not designed their version of the spring less valve system. I would guess if the gains were that much better they would have.
Old Feb 3, 2010 | 10:34 PM
bossco's Avatar
Desmodromic was the first thing that popped into my mind when I oped the OHV vid.
Seems to me somebody some while back made mention of a conventional valvetrain really not being that bad in terms effciency, but I can't remember the stated reason?????
Old Feb 3, 2010 | 10:46 PM
Threxx's Avatar
Almost 10 years ago people were talking about camless engines with electromagnetically controlled valves. But in the last 2-3 years I've heard almost nothing about it. What's up with that?
Old Feb 3, 2010 | 10:56 PM
DvBoard's Avatar
They just aren't reliable enough in an engine environment I'm sure.
bossco's Avatar
I think there were cooling and power requirement issues with the e-valvetrain. Wasn't Mercedes the last big name guys to take a crack at it?
Old Feb 3, 2010 | 10:58 PM
SSbaby's Avatar
Yes, that's what we were all hoping the C7 would come out with (according to internet rumours).
The camless engine needs 42V electrical power to work properly but there are cost and longevity issues to overcome.
Pros and Cons
What are the pros and cons? First, there is no technical challenge posed by 42V systems that cannot be solved. The real issue is cost, particularly as it compares to the current 14V system.
<>For example, 42V system batteries capable of offering comparable life with current 12V batteries require more costly technologies, such as lithium or nickel-metal hydride, to implement. Arcing and corrosion issues can be addressed through the addition of battery disconnect switches and sealed connectors at an added cost.
Suppliers will continue to improve technology to reduce the cost of solving the technical challenges. At the same time, the applications for electronic and electrical systems will continue to grow. As the relative cost of 42V systems decreases and the electrical content grows, the rate of 42V system adoption will gain momentum.
Supplier challenge
For suppliers of electrical and electronic components, what does the current situation entail?
Companies must continue to both optimize the capabilities of 14V systems and address the challenges of 42V systems. This must be done on realistic R&D budgets that reflect the economics of our times.
Thus, a coordinated effort in technology and product development must be made to ensure the most effective use of limited resources.
http://www.automotivedesignline.com/howto/199201615
Old Feb 3, 2010 | 11:08 PM
Northwest94Z's Avatar
I like the idea of improving OHV engine technology but is more horsepower worth reduced reliability?
What I see from that setup is many more parts = many more possibilities for failures. The beauty in the OHV engine IMO is it's simplicity yet outstanding performance.
Old Feb 3, 2010 | 11:11 PM
Z28x's Avatar
Me too ever since they were rumored to be on the Z06 that came out 4 years ago.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
willismoons
Feb 14, 2015 08:42 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
