View Poll Results: Should the 5th Gen V8 run on 87 Octane?
Yes, it should run fine on regular unleaded (87)
46
66.67%
No, it should run on premium (91+)
23
33.33%
Voters: 69. You may not vote on this poll
Should the 5th Gen V8 run on 87 octane?
Re: Should the 5th Gen V8 run on 87 octane?
It was my understanding that modern ECM's are sophisticated enough to pull the timing if detonation is detected so you can run the lower octane fuel without hurting the engine.
I'm pretty sure that's what my wife's Infiniti G35 does. The owners manual states that you can run 87 octane fuel, but to get "optimum performance" you need 92 or higher.
Originally Posted by muckz
Well, Diesel gets its name from its inventor, Rudolf Diesel. Miller gets its name from its inventor, Ralph Millerf, who patented the technology in the 1940s. The regular engines are actually Otto-cycle engines because they were invented by Nikolaus Otto.
A Miller-cycle engine uses a supercharger, but it also leaves the intake valve open during part of the compression stroke, so that the engine is compressing against the pressure of the supercharger rather than the pressure of the cylinder walls. The piston does less work because part of the work is done by the supercharger. The piston compresses about 70 to 80% of its total movement upward in the compression stroke, and the other 20 to 30% are essentially "free ride" with no energy loss. This cycle works only if the supercharger can compress the air in the cylinder at less energy than the piston. Hence, it has increased efficiency.
Ah well, my thinking is that Miller and Atkinson's should really be considered subsets of Otto types, since essentially you can do a cam swap to change them. However you can't change an Otto to a Diesel or Wenkel with just a cam (or a cam+SC).
Originally Posted by bossco
yes, but I beleive it was a miller cycle engine IIRC??
Sitting Bull
56
Feb 15, 2005 10:59 AM
Z284ever
15
Jul 31, 2002 02:07 PM
newby
10
Jul 27, 2002 11:39 AM
CamaroRSguy
12
Jul 8, 2002 09:39 PM
