More E85...
Re: More E85...
Originally Posted by Chrome383Z
The entire Midwest IS covered in Cornfields...
But if the fuel was all it is hyped up to be, the country would be switching over much quicker. Switching costs between the fuel types are not prohibitive (replacing a station's midgrade with E85 would work nicely) and there are are many benefits to gain from the switch. If Bush really intended to fight this country's "addiction" - the governement would dump $40B and convert EVERY gas station in the US to E85. That would send a strong message and the demand would skyrocket. Unfortunately for us, spending that cash rebuilding a foregn infrastructure is more important.
Obviously the administration has reservations about this fuel or they would have jumped on it - and the entire mid-West would vote Republican for years to come.
1) No real legislation from Govt yet. Due to the low cost of Gas (relatively) they are going to need help getting over the hump per say to compete against oil.
2) It's just not quite there as far as cost competitiveness with Petro. BUT like said above the technology is improving faster and faster, and oil is getting more and more expensive. So while this year or next year it will probably not take off huge, but in the next 10 years I expect to see alot more E85 stations popping up.
Re: More E85...
In a given engine- let's use a typical 9.5:1 V6 engine- you will lose both power and mileage by switching from regular 87 octane to E85 (which is 105 octane, IIRC). The E85 has less total energy content, and a given engine will not be able to extract as much energy, timing adjustments or no.
Now, if you build the engine to take advantage of E85's octane, the efficiency curve ratchets up quite a bit. Let's say you build a 12:1 motor, tune it for E85, and you're likely to see a reasonable increase in fuel efficiency over the 9.5:1 motor. Compression ratio makes a big difference in combustion efficiency. It's been a key contributor to the slightly increasing fuel mileage numbers we've seen in the past few years. 11:1 motors are popping up in all sorts of "ordinary" vehicles.
There's a study floating around somewhere, where they did just this, and proved the modest improvements.
I don't know why everyone isn't including Flex Fuel programs in their new vehicles. What does it take- two fuel/spark maps, and some Viton in place of silicone? Big whoop.
I'm not totally on board with Ethanol production, but I'll take it over sending you whippersnappers to the sandbox to protect my gas bill.
Re: More E85...
Originally Posted by maksik7
Pardon my ignorance, I have never been west of Pennsylvania. Those landlocked states scare me.
They already received something like $7B in 15 years, plus ~0.10$/gallon tax credit. Works out to about $0.45-0.50 of each E85 gallon subsidized by your taxes.
I hope so, and I also hope that if it is a proven technology - it is entirely backed by the gov't. The alleged benfits far outweight the limited expense. However for now, the White House supports the initiative half-a**ed, so how can the public be expected to act differently. Actions speak louder then words.
Obviously the administration has reservations about this fuel or they would have jumped on it - and the entire mid-West would vote Republican for years to come.They already received something like $7B in 15 years, plus ~0.10$/gallon tax credit. Works out to about $0.45-0.50 of each E85 gallon subsidized by your taxes.
Re: More E85...
Re: More E85...
Dont think Corn is the only crop you can make Ethanol from. Sugar cane and sugar beets also can be used to produce ethanol. Matter of fact you could probably get it from just about any crop. I know Brazil uses Sugar Cane in their ethanol production and it has helped them reduce their oil dependancy to about only 15%.
Re: More E85...
Originally Posted by 90 Z28SS
We have a pretty large ethenol refinery here in South Bend . When the wind is blowing just right , the smell this refinery gives off is GROSS . Everywhere smells like yeast , ick . Over the years it has improved significantly though . Back when they first built it years ago it was gagging almost .
Re: More E85...
Originally Posted by slt
There used to be a lot of oil refineries across the river from St. Louis. Most of them have closed down, but back in the 80's when they were running full speed, it stank. Baad. Must be the nature of the beast.
Re: More E85...
Well from everything I've read people get a boost by putting E85 in? Must be because the computer can get more aggressive with the timing?
EDIT- Here's some really old info. http://www.ilcorn.org/Ethanol/85__Et...__ethanol.html
It does illustrate that Flex Fuel vehicles are not a new thing.
Re: More E85...
There is soooooo much corn sitting around right now it's pitifull!!! In fact in my home town there is still a mound of it from 2 years ago all covered up and ready to go.
I do believe that this is the way to go but I will say one thing, corn priced suck right now and with all of the corn sitting I still thing the majority around here will be planting Soy beans this year even if it requires more work because of crop rotation... it's just where the money is right now...
Re: More E85...
Who are "people?" And, generally speaking, the computer doesn't get more aggressive (we're talking non flex-fuel vehicles here). The computer doesn't advance from the timing curve- it merely pulls back if the knock sensor says so. So, unless the engine is is constant knock retard, there isn't much to be gained.
All I was saying is it's possible Flex Fuel vehicles spark curve for E85 is more aggressive then the standard Gas curve and therefore = more power.
"More People" was a farmer who has a Tahoe I believe that is Flex Fuel. He mentioned it had more "Umph" with the E85... Of coarse maybe it's in his head, heh.
Re: More E85...
But in LS1's that recommend premium they have two spark tables and if it senses knock immediately (87) it will run on the milder one. If it doesn't sense knock (92) it will stay in the more aggressive curve which will produce more power.
In any case, until engines are built mechanically to optimize usage of E85 (meaning really high compression ratios, basically), then I don't expect to see any gains from its use, power or fuel economy-wise. Perhaps we're on the verge of that now, though, with CRs approaching 11:1 for "everyday vehicles."
I wonder if the hybrids would run better on E85. The Prius runs 13:1 CR (albeit with weird intake valve timing to approximate the Atkinson cycle, IIRC). Perhaps they could introduce a second VVT table to raise DCR for efficiency, along with more timing. The tech is in place.
Then again, maybe more DCR isn't right for hybrid efficiency... hmm...
My head hurts.
Re: More E85...
Yeah, I agree if we do make the switch over to E85, it seems only logical that we would increase compression ratio's to utilize the higher octane in the E85.
Anyhow, I think we need to concentrate on getting the price below gasoline first, heh.
Re: More E85...
From what I understand, we don't have enough corn fields to produce enough ethanol to meet our current oil demand, by far. At least as long as we decide that we also need to grow food.
Ethanol from switch grasses and what not helps, and it should also be more efficient, since it doesn't need fertilizers, etc.
Re: More E85...
