CTSV performance numbers
Old Jan 1, 2004 | 12:24 PM
GN1270's Avatar
Hope this hasn't been posted. Its off GM's website.
CTS-V's 5.7-liter V8 engine generates 400 horsepower and 395 ft-lbs of torque
Most powerful engine in its class—highest horsepower and most torque* Light, strong all-aluminum construction, 2-valve cylinder heads, 0-60 in 4.6 seconds, ¼ mile in 13.1 seconds/107 mph. * Based on latest available competitive information.
back to top
CTS-V's LS6 engine is mated to the Tremec T56 transmission
The Tremec T56 6-speed manual transmission features: Limited slip rear differential carries a performance final drive ratio of 3.73:1 to improve acceleration, Dual mass flywheel for reduced noise and vibration, Heavy-duty, increased diameter, 70-mm prop shaft, for CTS-V's higher torque requirements.
back to top
CTS-V's impressive braking enhances performance
Following extensive research at the Nurburgring test track, the CTS-V is equipped with a robust brake system for high-performance driving. Vented front 4-piston caliper Brembo brakes with 355mm x 32mm 14-inch rotors, Vented rear 4-piston caliper Brembo brakes with 365mm x 28mm 14-inch rotors, Stopping distance: 122.7 feet.
back to top
CTS-V achieves superb stability and handling with StabiliTrak and suspension tuning
Chassis refinements: Four-channel StabiliTrak with four driver select modes including one for performance environments, Large front and rear stabilizer bars to handle the high horsepower and torque, Increased diameter shock absorbers, Tower-to-tower cross bar brace enhances steering precision and responsiveness, Seven-spoke, 18 X 8.5 inch aluminum wheels with 245/45 Extended Mobility Tires, Lateral g: .91.
back to top
CTS-V exterior and interior styling contributes to the vehicle's performance character
Styling for vehicle and driver performance. V-Series badging and stainless steel wire mesh grille, Low front and rear fascias with aerodynamic side rocker panels, Stainless steel, oval, dual exhaust tips, Aircraft style instrument cluster features two driver information centers displaying performance functions, Sueded-material fabric inserts on all driver and passenger seating surfaces, Leather wrapped steering wheel with aluminum bezel, Satin chrome finish on grab, door handles, and shifter ring cap, Raven Black and Light Platinum exterior colors, Light Neutral and Ebony interior colors.
back to top
Old Jan 1, 2004 | 03:33 PM
guionM's Avatar
Re: CTSV performance numbers
back to top
back to top
back to top
back to top
back to top
Old Jan 1, 2004 | 03:38 PM
guionM's Avatar
This should hopefully put the "Nothing quicker than Corvette" urban legend to rest. The CTSv is slightly quicker than the base Corvette, and merely a couple bats of an eye slower than a Z06 to 60 mph.
Old Jan 1, 2004 | 03:43 PM
SNEAKY NEIL's Avatar
I bet it is even faster than the GM website claims since they always state perfomance figures on the conservative side.
Old Jan 1, 2004 | 03:45 PM
Melee Penguin's Avatar
I don't think the "Nothing quicker than Corvette" is untrue. I just think it mainly applies to Chevrolet. Same with I don't think the GTO will be topped by anything Pontiac. The CTSV IS supposed to be the "official" sports Caddilac correct?
EDIT: How will the CTSV stack up against the C6 or the upcoming C6 Z06?
Old Jan 1, 2004 | 03:57 PM
GN1270's Avatar
Its comparing apples to oranges. I don't think GM would have a problem making a Caddilac faster than a Corvette. I'll be trading in the vette for the V since I just had a new baby and now have 2 kids, and yes, those #'s are problably "I'm a decent shifter" #'s and with a good driver i'm sure 12.7's are possible. If someone can bring the same motor to an 11.99, a 12.7 should be possible in a car that weighs 500#'s more.
Old Jan 1, 2004 | 05:11 PM
hp_nut's Avatar
Re: Re: CTSV performance numbers
Sounds good. The E55 and 2005 M5 have gone on to the next level but they continue to be about $25K more also.
The CTS-V is dead on with current M5 and old E55.
Well only if it beats the official GM numbers. The current base C5 hardtop runs about a 13 flat @ 109 or so. But I agree that the published numbers are conservative and the CTS-V will most likely be slightly faster than the C5.
The C6 however will again undeniably regain top performance. When does it go on sale? Both CTS-V and C6?
I dunno about going with the current LS6 motor. It seems obvious the CTS-V will get the '05/'06 Z06 500hp motor. If we know that, then only the uninformed are going to jump on the 5.7L '04 CTS-V only to get pissed off when 100 more hp comes down the pipe for the same price in '05.
Old Jan 1, 2004 | 06:04 PM
Chuck!'s Avatar
Are they shipping the CTSv yet?
Old Jan 1, 2004 | 08:28 PM
RiceEating5.0's Avatar
True, but this is a 50k caddy, not a $24-30k camaro.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
cmsmith
Apr 1, 2015 09:29 PM
jrp4uc
43
Sep 18, 2002 08:26 PM
