2015 Chevy performance line-up. Let's have some fun!
Old Sep 24, 2009 | 02:43 PM
Z284ever's Avatar
C7 Corvette
Z06: 6.2L Gen V smallblock, DOHC, 525 hp, 2950 pounds, 31 mpg.
Base: 6.2L GenV smallblock, cam in block, 445 hp, 3000 pounds, 33 mpg.
Camaro (Alpha)
Z/28: 6.2L Gen V smallblock, cam in block, 444 hp, 3450 pounds, 30 mpg.
SS: 6.2L Gen V smallblock, cam in block, 395 hp, 3550 pounds, 32 mpg.
RS: 2.0L turbo, DOHC, 305 hp, 3350 pounds, 34 mpg
Cruze SS: Sedan and coupe 2.0L turbo, 305 hp, DOHC, 3200-3400 pounds, 36 mpg.
Orlando SS: same as Cruze.
Aveo SS: 1.6L turbo, DOHC, 200 hp, 2750 pounds, 38 mpg.
Volt SS: ?
Just for fun guys....
Old Sep 24, 2009 | 02:48 PM
Darth Xed's Avatar
I would hope there would be a proper Impala SS on a RWD platform with a DI V8 and optional AWD.
Old Sep 24, 2009 | 02:51 PM
Z28x's Avatar
I don't think we will see a sub 400HP 6.2L. We could see..
400HP-425HP DI 5.3L/5.5L
400HP Turbo DI 3.6L
330-350HP 3.6L-4.0L DI V6
Automatics will also be 8 speeds.
Old Sep 24, 2009 | 02:52 PM
Z28Wilson's Avatar
I like that lineup. A lot. Will we see the 6th Gen Camaro as early as 2015?
Originally Posted by Z284ever
Volt SS: ?
Flux capacitor, 1.21 jigawatts.
Old Sep 24, 2009 | 02:56 PM
Chewbacca's Avatar
Damnit, beat me by four minutes.
Old Sep 24, 2009 | 03:06 PM
Z284ever's Avatar
We'll see. One thing with all the new tech the Gen V's will have, don't expect a whole bunch of power increases over the Gen IV. It'll mostly be soaked up by emissions. So a 425 horse 5.3 is probably not happening.
Also, that 5.5L displacement which the GT2 C6.R gets...
I was kind of fascinated with that, so I did some checking. Don't expect that displacement on production cars.
Old Sep 24, 2009 | 03:08 PM
Z284ever's Avatar
Unknown. The sooner Caddy gets it's ATS coupe---> sedan--->convertible, the sooner work commences on Camaro.
Old Sep 24, 2009 | 03:11 PM
Z28Wilson's Avatar
Indeed. Heck, just give it Charlie's base Corvette motor in SS trim.
Old Sep 24, 2009 | 03:13 PM
96_Camaro_B4C's Avatar
Was that DOHC Z06 comment purely for fun?
I would so dearly love to see a Vette ring in at 2900 lbs. The current Z06 is ferocious with 505 hp and 3130 lbs.
525 hp and 2900 lbs would be magical. Near ZR1-level, actually. 550 hp would give it the same weight/power ratio as the ZR1.
I wouldn't mind seeing the redline climb to 7500 rpm either.
Old Sep 24, 2009 | 03:16 PM
Z284ever's Avatar
For fun, but......not based on pure fantasy either.
Old Sep 24, 2009 | 03:18 PM
Zigroid's Avatar
I cant wait to see the genV small blocks with VVT, direct injection, cyl deactivation, plus all the other cool stuff I cant think of that GM engineers are probably working on.
there are big gains to be found in VVT. check this out:
http://www.ls1tech.com/forums/dynamo...omparison.html
advance the cam for low end and mid range grunt. retard the cam for top end power. now we need the viper's cam inside a cam so we can have fun with the lobe separation angle.
Old Sep 24, 2009 | 03:19 PM
Z28Wilson's Avatar
Wouldn't it be more appropriate to save the DOHC V8 for the ZR1? You know, that whole LT5 connection?
Is GM really developing a whole different SBC engine architecture for one Corvette model?
Old Sep 24, 2009 | 03:21 PM
Z284ever's Avatar
Same architecture.
Old Sep 24, 2009 | 03:35 PM
Z284ever's Avatar
Nobody wants to talk about the Aveo SS or Camaro RS?
Old Sep 24, 2009 | 03:40 PM
Sixer-Bird's Avatar
Am I weird for hoping that they stick to OHV V8s?
I think RS will remain a package to be applied to base V8 Camaros, not a seperate model.
