2011 Mustang GT, 26mpg highway
Old Mar 18, 2010 | 02:41 PM
  #121
transam8's Avatar
This thread almost makes me miss the 3rd vs 4th gen and Z/28 vs SS "debates"...almost
-Mike
Old Mar 18, 2010 | 03:01 PM
  #122
STOCK1SC's Avatar
Originally Posted by bkpliskin
If performance for the dollar is big on your list, you should never buy a new car. Best performance for the dollar will always be had by buying a used performance car.
We aren't discussing used cars here, the discussion was about the new mustang and the new camaro, I'm sure I could find a crotch rocket for $10k that would decimate every car on the street or I could find a $500 VW bug and drop a 350 in it but that's not the point.
Old Mar 18, 2010 | 04:33 PM
  #123
Chewbacca's Avatar
Originally Posted by jg95z28
You guys are failing the grasp the physics of it all. Sure adding 600 pounds to an existing chassis is going to effect handling. However if the vehicle is designed from the ground up to include that additional weight, it doesn't matter a hill of beans.
Wow. Someone is failing with the physics here but it's not "you guys".
I'll go call Ross Brawn right now and tell him to stop wasting time and money with all those lightweight unobtanium components. He's so dumb. Every year he builds cars from scratch and never thought to account for weight from the ground up. Think of the money he could have saved by not having to focus on cutting weight from the cars.
After I speak to him, I'll track down the Corvette engineers and inform them of the same. Especially the old C5 team. Silly guys.
*NOTE* The sarcasm you just experienced was real and used with the intent of making a point. Weight matters. Period. Its effect does not magically disappear because vehicle dynamics are not well understood by the everyday driver. Practically no vehicle I can think of was built to be heavy on purpose or by accident. Ferchrissakes, my 2500HD has a magnesium transfer case. Some cars are heavier than others due to content and because there are limitations to what you can do with a given starting point, not because the weight voodoo was used during design and mass is now irrelevant.
Old Mar 18, 2010 | 04:35 PM
  #124
teal98's Avatar
Originally Posted by Z284ever
One thing to keep in mind Jeremy, is that yes, the 3rd gens were heavier than the the Fox Mustangs by about 150-200 pounds, (which weighed about the same as the Corvette) - but they were dramatically better cars than the Fox Mustangs.
In many ways, the 5.0's were one trick ponies, thrilling in a straight line, but with crappy brakes (yes, even crappier than F-cars), scary high speed dynamics, and archaic suspension, cheap interiors and fairly poor handling. And when GM got it's powertrain act together, the 5.0's weren't even faster, (or that much faster) in a straight line in most cases.The F-car was the finer car in most categories including looks, handling, steering feel, high speed stability, interior, etc. It was both nicer and more FUN to drive.
Compare all that with today's cars...
So in the end, it's not all about the weight, it's about the drive. I've never seen you concede that before. Maybe I missed it.
Old Mar 18, 2010 | 05:10 PM
  #125
Z28Wilson's Avatar
It's about the drive, and the drive is very different for a 3300 pound car (albeit heavier than the Mustang of the time) and a 3900 pound car (today's Camaro V8). It's kind of silly to say that because Camaro drove so excellently weighing 200 pounds more than Mustang in the 80's and 90's, there is no problem that it weighs so much more today because it maintains the same gap.
To illustrate, let's look at your run-of-the-mill LT1 F-body. That car weighed in around 3400-3500 pounds. At the same time, the full-size Impala SS was just over 4000. 500-600 pound difference, right?
Fast forward to 2010. You have a Camaro nipping at the heels of 4000 pounds, and a full-sized G8, again, weights just over 4000 pounds. We've gone from a sporty coupe several hundred pounds less than a large RWD sedan of the same vintage to a coupe that practically mirrors the large sedan. That's the underlying problem here.
Old Mar 18, 2010 | 05:11 PM
  #126
Z284ever's Avatar
Are you saying that you don't believe that "the weight" has anything to do with "the drive"?
Old Mar 18, 2010 | 05:27 PM
  #127
SSbaby's Avatar
Originally Posted by Z28Wilson
Of course it does. But like I said, the original point is that we're comparing engines in a vacuum so to speak, not the cars that surround each. You can't measure an engine's output using anything other than a dyno. Your "butt dyno" doesn't qualify because the car is the variable.
I perfectly understand what you're saying about heatsoak BTW.
The keyword here is "some". You have to rev the crap out of a lot of Honda 4-cylinders to keep them in the powerband, but they'll still get decent mileage. It just depends on how you want to drive it.
Again, the EPA test is not perfect but it does seem to say that the 5.0 will be just a little bit more efficient over a full range of driving than the LS3. This makes your point about high-revving efficiency moot. Maybe we shouldn't blame the LS3, maybe we should blame it on the extra junk in the trunk which it is tasked to haul around.
You can't compare a high revving, 4-cyl engine's fuel consumption to a V8's because the engine 'load' is vastly different. With 4 cyl engines, you can get away with good fuel economy with frequent open throttle bursts without putting a severe dent on your fuel bills. If you drive the same way with a V8, it would use more fuel (derr!) but you don't need to do that. If you drive a V8 only as hard as you need to, to keep up with the hard revving 4 cyl, you can still manage reasonable fuel economy because the engine load is relatively low for a V8. The comparison being, equal work is performed by both engines.
That's why we are making an apples to apples comparison (V8 vs V8). There's various factors that influence fuel economy. That we can agree on. I do believe that the Coyote will be slightly more economical on the hwy than the LS3, both driven gently and at optimum, cruise-friendly revs (gearing aside).
But to use EPA numbers to arrive at the conclusion that the Coyote is better under all conditions is over-simplifying things.
Old Mar 18, 2010 | 06:14 PM
  #128
Bob Cosby's Avatar
What 2010 V8 Camaro weighs 3737 lbs? Title should be "How the Camaro gained 950 lbs over 37 Model Years", and appropriate graph and text numbers adjusted accordingly.
And it would be nice to see some real data on how the LS3 will get better mileage than the 5.0 Coyote in "spirited" or "performance-oriented" or any other type of "real-world" driving. Just stating factory rpm limits won't hack it, though I suppose the counter arguement to that would be the amount of air/fuel necessary to fill a cylinder that displaces .775 liters vice filling one that displaces .625 liters.....at WOT throttle, of course.
Old Mar 18, 2010 | 06:20 PM
  #129
teal98's Avatar
To me, there is a HUGE difference between weighing 3300 pounds and 3900 pounds, regardless of where you're at compared to Mustang at each point. While the 5th Gen's chassis is clearly superior than anything the 3rd Gen could have dreamed of, 600 pounds is like 3 grown adult males tagging along for the ride.
But everything has added a lot of weight since 1985. Nobody likes it, but the vast majority of cars out there have gained 20%+ since then (Corvette being a very notable exception -- shows us how fat it was back then relative to everything else and how well the Corvette team has done).
Old Mar 18, 2010 | 06:22 PM
  #130
teal98's Avatar
No. I'm saying that the drive has to do with more than the weight, or you'd be a Fox body fan instead of a 3rd gen F-body fan.
Old Mar 18, 2010 | 06:27 PM
  #131
teal98's Avatar
Yes, and please note that I did not say (or write) that silly thing.
But I do think that the Camaro can be and will be improved from where it is, even if it does not shed any pounds.
There's a lot of room to improve today's 3860 pound Camaro. Just last night, I was reading the April 2010 Road&Track where they described significant handling improvements in a Hennesey LS9 Camaro weighing 3939 pounds.
Old Mar 18, 2010 | 06:38 PM
  #132
Chewbacca's Avatar
I also agree with this... HOWEVER... it will still not be as capable as a similarly enhanced 3560lb car.
Do you agree?
Old Mar 18, 2010 | 07:08 PM
  #133
Z284ever's Avatar
The argument that an '82 Z/28 weighing 3300 pounds compared to an '82 GT weighing 3100 pounds, somehow, in some perverse way, absolves the current car of it's sins - - is ridiculous. Don't you think? I mean don't you think that the Camaro could have performed even better, then or now, had it been lighter?
The bottom line was that the 3rd gen F-car delivered the goods against the Mustang, in spite of it's weight disadvantage.
I'll refer you back to what I said in post 116:
It would be hard to complain about weight in the 5th gen if you couldn't feel it. Or if it's dynamics belied it's mass. Or if it gave you goosebumps when you drove one. Or if it so completely outclassed the Mustang, the way the 3rd gens did. Of course, none of that is true.
Old Mar 18, 2010 | 07:16 PM
  #134
SSbaby's Avatar
I removed the link thinking it would only bring back the dead horse. One thing is certain from the article, the 3rd Gen was structurally the weakest of all Camaros. Some people don't care about that basic fact but that car would definitely be under-engineered, in my book.
If you want to provide data to back up your statements, hey, I'm not holding you back! It would be good to learn a thing or two from the master for a change instead of some unpopular Aussie who doesn't give a rat's whatsit about his rudeness to people who like to revisit weighty subjects.
Old Mar 18, 2010 | 07:24 PM
  #135
Bob Cosby's Avatar
I'm sorry, can you tell me again what claims I've made that need backing up?
