Autocross and Road Racing Technique There is more to life than a straight line
Will I feel the difference?
Old Apr 22, 2003 | 11:42 PM
CDN WS6's Avatar
Question Will I feel the difference?
I was wondering if I could get some opinions here. I have a 97 Trans Am WS6 and I am going to install the following parts,
1)BMR tubular SFC's
2)BMR LCA's
3)BMR bolt-in relocation brackets
4)Eibach sportline springs
5)I may buy a BMR STB
Now will there be a noticeable difference in the way my car handles? Also, next year when I upgrade my shocks I'm thinking of getting Bilstiens, how much will these help? Please give me your opinions and suggestions.
Thanks!
Old Apr 23, 2003 | 12:25 AM
Lady in Nomex's Avatar
I don't know about the BMR stuff - I have Global West stuff. Both product lines look beefy. I don't like the idea of a bended STB like BMR has though. There are several quality straight ones available.
I do know that you probably won't like the Eibach Sportlines- big drop; most folks get the Prokit. Recently I ordered some stuff from FS '01 Stranoparts.com
and let Sam make some changes to my set up on my '97 TA. I got my Bilsteins revalved to his specs for me, got a 35mm bar to replace my 1LE (G2) up front and some Ground Control Coilovers. The rear of the car will remain the same for now with Bilsteins, SLP Level 1 Eibachs and a 1LE (G2) rear bar. I suggest you give Sam a call and talk to him about your goals for the car before you buy anything.
Old Apr 23, 2003 | 03:58 AM
2002Z28SSConv's Avatar
Re: Will I feel the difference?
1)BMR tubular SFC's
2)BMR LCA's
Thanks!
Your sig says you already have relocation brackets. Whatever. You will notice a definate difference. Better or worse, who knows? I would get the shocks along with the springs and leave off the control arms if there was one thing you needed to leave off to save $$$. You have to remove the springs to change shocks. Either wait for the springs, or spring for the shocks too. A 35mm front bar really helps out in the twisties too.
You'll notice a big change just with springs alone. Each other addition will give mild changes too.
Old Apr 23, 2003 | 07:34 AM
CDN WS6's Avatar
I already have the springs, relocation brackets, lca's, sfc's and adjustable panhard bar. I chose the sportline mostly based on looks and also because I rode in my brothers 95 t/a, lowered 2 inches, and I likes the ride. Shocks will come next year as my brother's a GM mechanic and can install them at work after hours.
So Bilstiens are a good quality shock?
Old Apr 23, 2003 | 09:14 AM
AZ94FORMULA's Avatar
Sportline springs are for show, not go. I suggest returning them for the pro kit. Bilstiens are good shocks. Save your brother the time and hassel by installing the shocks and springs at the same time.
Kurt
DirtyDaveW
Dec 1, 2016 05:37 PM
emailname
Jun 14, 2015 03:14 PM
rocknroler69
Apr 29, 2015 10:24 PM
Apr 16, 2015 09:57 AM
Jan 23, 2015 01:13 PM
