Autocross and Road Racing Technique There is more to life than a straight line
Wheel Spacers
Old Jun 3, 2003 | 07:14 PM
bruecksteve's Avatar
Wheel Spacers
Does anyone know what the maximum thickness is for a wheel spacer using the stock studs?
Old Jun 3, 2003 | 07:39 PM
Sam Strano's Avatar
I wouldn't go much more than 1/4"...... ARP has really nice studs for our cars as another option. About $15 a pack.....
Old Jun 3, 2003 | 08:14 PM
Thanks Sam! I wanted to space out the 50mm ZR-1 wheel just a little bit. If I use the other studs, can I still use my existing lugs and locking lugs? Just waiting on the Ground Control stuff to arrive!!!
Old Jun 3, 2003 | 10:44 PM
Steve in Seattle's Avatar
yeah the threading is the same, although it goes right to the end of the lug, unlike the stock ones that stop the threading ~1/2" short of the end.
The ARP lugs, in addition to being stronger, and having more thread on them, are about 1/2" longer than stock. as a result, closed-end lug nuts (like your typical chrome acorns from Gorilla or McGard) will not fit. I have the spline-drive McGard lugs and just test-fit them on the ARP studs... I need to hack off about 1/2" from each. The advantage over stock will still be the strength of the lug and the threading all the way to the end.
If you plan on using a 1/2" spacer, the ARP lugs are sweet. Of course if you needed that much, you could have just bought the true ZR1 wheels and had a 36mm offset.
The only way I'd go with ARP lugs now is if I cut them back to stock length, or if I go to open-ended lug nuts.
hmmm... I wonder if McGard makes a longer-than-normal closed-end nut?
If you're insane about weight loss:
http://emporium.markwilliams.com/pro...sp?prodid=1079
titanium lug nuts @ $25 EACH.
better yet: http://emporium.markwilliams.com/pro...sp?prodid=1086
titanium stud kit w/nuts... $290 for 2 wheels worth.... and you save 1.2 lbs over steel versions
force10
Aug 10, 2015 08:30 AM
Slayer
Jul 4, 2015 03:06 PM
BLK1997Z28
May 2, 2015 01:26 PM
SpeedJunkee
Apr 23, 2015 09:51 AM
derty
Aug 31, 2002 12:28 AM
