Autocross and Road Racing Technique There is more to life than a straight line
Victoracers Tire Pressure
Old Jun 4, 2003 | 08:19 AM
Jeff94TA's Avatar
Victoracers Tire Pressure?
Just bought a set of 245/45 16 Kumho Victoracers and my first autocross on the new tires is this Sunday. What tire pressures work well with the Kumho's? Check my sig for my car and it's mods.
Old Jun 4, 2003 | 10:51 AM
KeithO's Avatar
I have a similar setup to yours, but no Eibach stuff.
I run about 35 front, 30-31 rear as a starting point and adjust from there.
Old Jun 4, 2003 | 06:19 PM
steve-d's Avatar
Hi all,
As long as we're talking about Victor tires, I've purchased a set for the track. Any suggestions as to TP? Thanks in advance.
Steve
Old Jun 4, 2003 | 08:27 PM
Jeff94TA's Avatar
Thanks for the response Keith and yes I'm curious about the track as well. My next open track event isn't until September but I would like those thoughts as well.
Old Jun 5, 2003 | 04:30 AM
KeithO's Avatar
I have only ever tracked on street tires (never on r-compounds - too expensive). In general, I put more pressure in my street tires for open tracking versus autocrossing. The reason for this is safety more than better handling, etc. When I autox on my street tires, I have run as low as 29 front, 26 rear. At autocross speeds, I won't go lower than this because I don't want to risk pulling the tire off the bead. For this same reason, I would likely go higher when I track on the Victoracers someday. My instincts would be to start at 38/35 and try to maintain this (or a slightly higher pressure) when the tires get hot.
Old Jun 5, 2003 | 07:27 AM
Jeff94TA's Avatar
I've only tracked the car once and it was bone stock at the time. I was running something like 42 front and 36 rear on my street tires just trying to save the outside edges. Still chewed up the fronts nicely though. Oh, BTW I'm talking hot pressures.
Old Jun 5, 2003 | 07:43 AM
KeithO's Avatar
OK, good point. Just to be clear. All of the pressures that I gave are cold.
Old Jun 6, 2003 | 02:05 AM
redimpss5's Avatar
keith, that helps a bunch!! if you drive to the track and check them then, it wont work!! drive there and let the car sit for a hour or so then adjust. this will help a bunch! remember, if you have to much pressure after you run, drop some. rule is, it is easier to let out then pump them up on grid.
Old Jun 6, 2003 | 05:21 AM
KeithO's Avatar
Everything that you say is correct. Whether it is an autocross or a track day, you typically show up early and end up letting the car sit, register, unload, go through tech, then wait a little longer before you run. I check the pressures during the "wait a little longer" phase of the day.
Also, to speed things up, I typically take my best guess on pressure, add 2 pounds, then come down as the event progresses. This is quicker and easier (especially at an autocross) than adding air between runs, just like you said.
Old Jun 7, 2003 | 05:09 AM
BobC's Avatar
on the track try 35f, 31r cold pressures. mark with white shoe polish.
Old Jun 7, 2003 | 05:13 AM
KeithO's Avatar
Hey BobC! Just to let you know, the Victoracers that I bought from you are very helpful. In fact, I call them "magic tires". I have run 3 events on them and won all three. I ran 4 others events at a club that requires true street tires for stock and I have 4 second places over there...
Old Jun 7, 2003 | 11:01 AM
chuck's Avatar
I run 32-33 rear / 37-38 front for autox.
RichJ
Sep 14, 2002 09:37 AM
Frank95z
Sep 10, 2002 08:30 PM
97bowtie
Aug 25, 2002 11:00 PM
Cap'n
Aug 19, 2002 11:33 PM
wytblur
Aug 5, 2002 02:03 PM
