Autocross and Road Racing Technique There is more to life than a straight line
Spring/shocks question
Old Nov 20, 2002 | 07:54 PM
Robbie_97z28's Avatar
Smile Spring/shocks question
Hey guys, I was told that LG springs would be a great addition to a non-auto-xing / road racing car. I love to carve corner however. So do you guys recommend the LG springs and Strano revalved shocks or what would be an SS killer on the corners? Thank alot fellas...
Old Nov 20, 2002 | 08:09 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
the pro kit +bilstien combo is enough for daily driving. if you are serious about autoX, etc.. get some Konis or revalved bilstiens.
Old Nov 21, 2002 | 11:58 AM
Here in Hawaii, if we drop our cars too much we have to apply for a special reconstruction sticker...gay stuff
Anyway, I'm not trying to drop it too much. I've heard that the pro-kit drops it over an inch... Not wanting to change bumpsteer kit if I don't have to...Thanks...
Old Nov 21, 2002 | 02:42 PM
94bird's Avatar
The Pro Kit should drop your car about 1.25" or so. The LG springs are closer to 1.5" I believe. You won't need a bumpsteer kit with either set of springs.
Old Nov 21, 2002 | 03:10 PM
Are any of you guys running this and if so, how well do you like it? I really appreciate the responses guys. Thanks for helping me out.
Old Nov 23, 2002 | 01:14 PM
2002Z28SSConv's Avatar
Sorry for the hijack.
It seems every body asks for a street combination. Can somebody recommend what combination is the best for an autocross type setup? Is lower necessarily better? Is the lowest the best?
I was thinking of going with DMS and revalved Bilstiens. But I'm not as concerned about getting too firm of a street ride. So I'm open to a lower/stiffer ride.
My Goal:
My times are usually about 3-4 seconds slower than the C5 Vettes with race rubber on a 50+ second course. I want to close that gap as much as possible. I don't expect to be able to beat them. But I want it to be as close as possible. I'm planning on upgrading to Hoosiers or VictoRacers early next year. I'm gonna go all out next year. I've done enough damage in Stock class. I'm moving up to Prepared.
All recommendations are appreciated.
Springs, Shocks, LCA relocation brackets, LCA's and APHB are in my plans. What combinations do you think?
Old Nov 23, 2002 | 03:47 PM
lons94z's Avatar
autocross setup
Depends on class. If you want to modify your car the only class you can be comp. in is ESP. Thats just fact, for anyone who trys to disagree.
So this can be real easy.
You need shocks, obviously.
You need springs. But not just to lower because of CG. You need to lower because you can pickup neg camber. Align with max neg camber and max castor. Toe is youre choice. I ran 0 all year but am going to a little toe out next.
Stiffer is not better. I am using a 500lb spring and 35mm front bar 125lb rear spring with a stock rear bar.
You need wheels and tires. I've used both so trust me. Skip the 275's and go strait to the 315's. Why not just do it right the first time.
You NEED a Torsen T2R this is a signifigant improvement over stock and one of the best mods done to an autocross car. Without question.
You will need a rod end PHR.
LCA and LCA brackets are not needed and will put you in a class you wont be comp. in. Local level sure. Unless a good driver in a better car shows up.
Old Nov 24, 2002 | 09:11 AM
SDA's Avatar
SDA
This is a neutral set up for street. 1LE ft. springs and stock rears.Strano bilsteins,35mm. ft.,19mm.rr.38-39lbs in ft. tires, 30 lbs. in rr.All the neg. cas. and cam. you can get.Make the chassis as stiff as you can.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
30thZ4C
Wheels and Tires
Jan 29, 2015 06:03 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
