Autocross and Road Racing Technique There is more to life than a straight line
Rear shock upper mount location for convertibles?
Old Aug 19, 2002 | 11:08 PM
Zedzag's Avatar
Post Rear shock upper mount location for convertibles?
I have a 95 Z28 convertible and was looking to see where the upper mounts for the rear shocks were.I had the carpet pulled back parallel with the "goalposts" or rear seatbelt towers and couldn't find any sign of where they are mounted.The only thing I had to go by was removal instructions for hatchback models.Are the mounting locations the same for converts?Maybe I'm just blind but I couldn't see any foam blocks covering the mount location.
Old Aug 19, 2002 | 11:34 PM
LPEdave's Avatar
Post
The mount points are about 6-8" below those seatbelt mount points, behind the rear seat back. There should be a perforated square cutout in the carpet that you'll need to cut and pull back to uncover the foam cover over the shock.
Dave
1997 LPE 383/n2o Camaro Z28 Convertible
12.39@112.2, 1.76 60' (na) 11.27@124.6, 1.76 60' (n2o)
LT1 Diagnostics, New to Nitrous? Northern California Racing Club
Old Aug 20, 2002 | 12:01 AM
Zedzag's Avatar
Post
Thanx for the help Dave!
Just took a look at your website and all the install info is right there.A very informative site.
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
87Aerocoupe
Jan 10, 2015 07:27 PM
Jul 4, 2005 05:00 PM
slothgrant
Aug 22, 2002 03:01 PM
Timberwolf
Jul 20, 2002 08:45 AM
