Autocross and Road Racing Technique There is more to life than a straight line
rear camber?
Old Jul 30, 2002 | 11:09 AM
vals95z's Avatar
Post rear camber?
The other day I saw a somewhat ghettoish looking slammed BMW with what appeared to be negative camber on the rear wheels but none on the front. I was just wondering if anyone had seen anything like this before, and if it has any use...thanks!
Old Jul 30, 2002 | 11:26 AM
LPEdave's Avatar
Post
You're getting your performance tuning tips from "ghettoish slammed BMW's"??
He probably has a 200lb "system" in the trunk.
Dave
Old Jul 30, 2002 | 12:17 PM
vals95z's Avatar
Post
hehe...not looking to emulate this guy. Just wondering if his setup was as dumb as it looked
Old Aug 1, 2002 | 01:13 PM
Dave K's Avatar
Post
Kinda tough to emulate rear camber on a live axle car.
Old Aug 1, 2002 | 03:06 PM
Soma07's Avatar
Post
LOL LPEdave!
But anyways I would imagine negative camber in the rear serves the same purpose it does up front. However as Dave K mentioned the rear axle is solid on our cars therefore there is no way to adjust the camber back there.
Jason
93 TA, M6
Old Aug 2, 2002 | 04:10 PM
Dr.Mudge's Avatar
Post
You may well have some negative camber in the rear, CamaroMustangChallenge allows no more than -.5 in the rear, but as mentioned its not adjustable like thiers.
Old Aug 3, 2002 | 11:32 PM
DWoodAudio's Avatar
Exclamation
<font face="Verdana, Arial" size="2">Originally posted by Soma07:
LOL LPEdave!
</font>
Well, there IS, but its neither easy or cheap. You bend the axle housing, just a bit....can get about 1-1.5 degrees negative but its a job best left to an expert. Lots of the A-sedan guys do it, and I'm told by rumor that some of the T-1 and T-2 guys are doing it too, but not that they will admit to in front of a tech inspector.
Old Aug 4, 2002 | 06:46 PM
V6Bob's Avatar
Post
Not only is it not easy or cheap, it's not safe.
The NASCAR boys used to do it, until a number of axle failures made NASCAR clamp down. If you lose an axle it can easily cause an accident.
2000 Firebird convert, chameleon/tan, M5, Y87, TCS
KBDDs, BMR STB and Panhard, 245/50-16 GSCs
Old Aug 7, 2002 | 08:21 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
Post
.. hence the reason you should NEVER run c-clips!!
-94 Black T-Topped Z28 M6, 10s, and daily driven!
-96 CBR F3, modded of course
-92 Talon Tsi AWD, also too many mods..
-99 Tony Kart
http://www.fastblackcar.com
96SilverRam
Nov 20, 2016 11:19 AM
HarleyZ28
Oct 5, 2015 06:23 AM
BLK1997Z28
May 1, 2015 12:23 PM
sseeya
Apr 9, 2015 06:38 AM
