Ls1 brake upgrade or not
Okay, i've done the research and still can't really decide on whether or not to switch to ls1 front brakes w/ better pads or just put better pads on my existing brake system. The thing is, my brakes really suck right now, the car just plows forward with my foot firmly on the brakes. It's kinda scary sometimes. I don't know what pads are on my car right now, but they don't dust much and feel extremely weak unless warmed up, so they are probably junk. I've been told that upgrading the brake will not stop better but merely reduce brake fade. Since both systems will readily lock the wheels.
I need advice. For those who've done the ls1 upgrade, was it worth it? It's like an extra 200 bucks over the alternative. That 200 could be spent elsewhere.
Yea, i am trying to save money, hehe. Has anyone done both the better pads thing on the lt1 system and the upgrade? The lt1 system can't be all that bad if you can lock the wheels with 315 hoosiers. how fast were you going if i might ask.
Ok, the LT1 brakes ain't the greatest. LS1 brakes are easy to get and better. BUT, without putting good pads on the stock brakes, you aren't getting the best you can out of them, and shouldn't write them off without trying better pads, fluid and maybe lines.
Remember the magazine test a while back with the WRX and stock brakes with HP Plus front pads vs. 4 different big-brake setups (2 Brembo, Stop-tech, Prodrive)? The stock car with HP plus fronts stopped from 90 4 times in a row as well as they big brake cars. It was only after that the big brakes did better since they could shed off the heat more effectively. Compared to stock, the pads shortened all the distances a lot, and were much more fade resistant too.
I've driven cars both ways. If I was tracking the car a lot, or worried about the few pounds of unsprung weight the LS1 brakes save, then do it. But I think you'll be amazed how much a set of $75 brake pads will help on the front alone. You can also add better rear pads too. Better fluid certainly does not hurt, and it not expensive either. Even stainless lines are only a little over $100. For $200 you could add HP Plus fronts, stainless steel lines, and ATE Fluid and have much better brakes.
Since you are on a budget, I think it only makes sense to see if you can make what you have workable. The pads are less money than LS1 pads are, and as others with LT1's who've done HP Pluses can attest the power increase vs. even HPS's is not small.
No doubt the LT1 brakes do work remarkably well with a good pad. I had Perf. Friction pads and was amazed at how well they worked when hot, but that was the trouble: the PFC didn't get hot enough to be really effective on the street and that left me with lousy brakes most of the time. I simply could not get ABS to kick in with the things, and that concerned me a great deal.
HP Plus work fine for everyday driving, they ain't the cleanest things in the world, but they work great. As for the track. This is sticky. YMMV, some guys have no trouble at all with HP Pluses, some guys need more. Many things play into it. How torturous is the track on brakes? How hard are you on brakes? Do you expec them to hold up no matter what?...... and so on.
As far as I'm concerned the HP Plus is the only pad that can truly do both, but it is NOT a track pad. If if works for you great, if not, it's time to step up to a dedicated track pad.
Well I'm about to take the step into tracking more heavily this coming season. The track that I would be at most often has two rather long straights at which speeds will reach 100mph. They then turn rather abruptly, so these are heavy braking zones. I ran there once last summer and really put a strain on my stock pads. They are nearing extinction, now. My wheels got so hot that the centers, which were glued on before the event, were no where to be found at the end of the event. Having said that, I will say the stockers held up quite well, and didn't really fade badly at all, so maybe I'm not using the brakes as hard as some.
Are there different grades of Hawk pads, Sam? It sounds to me like the HP+ might be good enough for me, but is there a step up that is not full race? What price, BTW?
The plus pads are not full race pads. I use them on my street car yet they're awesome for autocross or a little track use. I have no cold stopping problems nor do they fade at all.
Well I'm about to take the step into tracking more heavily this coming season. The track that I would be at most often has two rather long straights at which speeds will reach 100mph. They then turn rather abruptly, so these are heavy braking zones. Having said that, I will say the stockers held up quite well, and didn't really fade badly at all, so maybe I'm not using the brakes as hard as some.
