Lower control arms with independent caster and camber adjustments
Chromoly fully adjustable
Here is a link to a pic
http://www.millerracecars.com/
What do you guys Think
ED
95 Formula Solid Roller 9 Inch 4.10 H.D. Locker,6 speed
Best 1/4 12.074 Best MPH 115.56 on STOCK HEADS
94 Hardtop Heads up Drag car
94 Formula A4 Stock
120,000 miles 13.82
Tow Rig 84 suburban 3/4 4wheel drive 388 small block
ED
94 Formula A4 Stock
120,000 miles 13.82
The one little picture looks nice, but it doesn't have any information. How much?
Thunder Racing sells 2 different brands of front lower control arms with spherical bearings. Did you check out their website?
www.thunderracing.com
Kurt
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
Kurt
