Autocross and Road Racing Technique There is more to life than a straight line
Does anyone make two-piece rear rotors?
Old Jul 28, 2002 | 07:43 PM
Curt (pres AAMC & ZAA)
Guest
Posts: n/a
Question Does anyone make two-piece rear rotors?
I'm doing a front brake conversion on my 95 Formula, and would like to use two piece rotors all the way around. I've found them for the front -- Eradispeeds and "standard" Baer two-piece rotors (I was told the only difference between the Eradispeeds and the Baer standards is that Eradispeeds comes with all the options -- cross-drilled, slotted and zinc plated).
But I haven't been able to find the two-piece rotors for the rear in the stock size for 94-97 F-bodies. Does anyone know of a manufacturer?
I know that I don't need two piece rotors, but I want them
Old Jul 29, 2002 | 07:12 PM
Pat Newton's Avatar
Post
Why?
Pat Newton
'97 Formula - unstock
'85 BMW 524 turbodiesel - stock and stinky
'90 Mazda Miata - Spec Miata race car in progress
http://home.attbi.com/~patricknewton/f-body/formula.htm
Old Jul 29, 2002 | 07:42 PM
Guest
Posts: n/a
Exclamation
Because I can (that is if anyone actually makes them!)
I'm looking for a good looking rotor as well as a good peformer.
Old Jul 30, 2002 | 12:57 PM
I B JAMMIN''s Avatar
Post
The Wilwood kit for the rear has a 2 piece rotor. The hat functions the same for the parking brake but you need some additional hardware.
see:
http://www.wilwood.org/fl89.pdf
Old Jul 30, 2002 | 09:26 PM
Guest
Posts: n/a
Post
I've looked at several aftermarket rear brake kits, but I don't think there's any real gain to be had changing them. I've had several leads on two-piece rotors, but nothing has panned out so far. The big three -- Wilwood, Baer and Brembo don't make them, so I've turned to a couple of smaller companies (some of which are using custom Wilwood rotors) but haven't heard anything back yet. I'm guessing that I will either come up empty, or it will be waaaaay too cost prohibitive to pull it off. So I guess the next thing I need to do is find a decent looking, good performing set of one-piece rotors.
What's everyone's thoughts on the Powerslots? I've heard mixed reviews, so I'm unsure.
Initially, I'll probably just use the stock C5 rotors for the front, and keep the GTRotors I already have on the back. I may bead blast them and hit them with a coat of paint so they at least look semi-decent. The gold color of the GTRotors has driven me nuts forever!
Old Aug 1, 2002 | 12:41 AM
AZ94FORMULA's Avatar
Talking
For starters, you spell your name wrong!!!!
I've been using Powerslots in the rear for several years. I'm currently using full race pads and I only use my car for road racing. So far, no problems. They are zinc coated, and they still look brand new. I would only use Powerslots on the rear brakes, because they don't take as much abuse as the fronts. I'm buying 2 piece Eradispeed rotors for the front. I hope they last longer than the original 13" rotors that came with the Baer Track kit.
Or you could try KVR rotors. Check out this website: http://www.fasttoys.net/9398fbodyframes.html
Kurt
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
[This message has been edited by AZ94FORMULA (edited August 01, 2002).]
Jazsun
Dec 29, 2014 12:14 PM
bossco
Nov 29, 2014 10:18 AM
siguy
Nov 27, 2014 10:07 AM
