Autocross and Road Racing Technique There is more to life than a straight line
Coil overs??
Old Jun 7, 2002 | 01:03 AM
jj93z28's Avatar
Question Coil overs??
Hows it going? Well I am new to suspension mods and am looking for a little help locating a coil over kit, the LG kit is to pricey for me. A explaination as to why this is better then just regular lowering springs would be nice to. I am guessing its the adjustability.
[This message has been edited by jj93z28 (edited June 07, 2002).]
Old Jun 7, 2002 | 01:57 AM
Dr.Mudge's Avatar
Post
Adjustable ride height, "any" spring rate you want, corner weights, lighter than stock setup, or save your money.
Old Jun 7, 2002 | 03:46 AM
jj93z28's Avatar
Post
I see, so how do the other coil over kits compare to LGs one. Keep in mind I am not a serious racer so I can settle for little less than perfection.
Old Jun 7, 2002 | 09:42 AM
Lowend's Avatar
Post
checkout:
www.groundcontrol.com
www.globalwest.com
both of these companies make coilover setups for 4th gens.
I have used the Ground Control and it works very well.
The GW kit is nice in that it is tuned to work with the other GW products (torque-arm, LCA's/brakets).
The truth be told, if this is a 100% street car, a set of coilovers is probably not the best use of your $$.
Coilovers do allow adjustability, which is crittcal on a racer; but for a street car how valuable is that...
I would probably invest in a set of Lowering springs, and spend the extra $$ on a set of good weld-in SFCs.
1971 Camaro
12" brakes
16x10" wheels
VSE swaybars
350 / M21
Autocross Competitive
'83 FSP GTI (driver)
Administrator; 2nd Generaton Camaro Owners Group (2GCOG)
www.nastyz28.com/2gcog/2gcog.html
Sales / Tech
"The Speed Merchant" - San Jose, CA
http://www.speedmerchant.com/
Old Jun 10, 2002 | 09:18 AM
auto-Xer's Avatar
Post
Something else about the LG setup is that its the only one that is rodended, which if your seriously roadracing, is a big plus when making your choice. For a daily driver, it means little though.
--Kevin
'96 Z-28
78k Miles
Toyo RA1 275/45Z17, SLP Coated Headers, SLP Clutch and Flywheel, G2 Coilovers (Bilstein and Eibach), LS1 Driveshaft, G2 PowerPulley, G2 CAI, B&M Ripper, G2 Pedal Covers, TB Airfoil, Borla 3" catback, G2 Panhard Rod (adj. w/ rodends), G2 Subframe Connectors, G2 Enginebay Brace (4 point), G2 Swaybars, Poly Trans Mount, Driver & Passenger Sparco Evo2 Seats, Powerslot Rotors w/ PFC Pads, Stainless Steel Brake lines, ACES SureShift2 Seq. Shift Light, Spohn Torque arm, LCA(rod/poly) and relocation bracket, McEwen White Gauge Faces.
On order: Autopower 'race' rollbar, Spacro 5 point harness, McCord Power Plate cutout, LG Spoiler and stripe, and ScanMasterLT1
Just a few parts away from my ZR-28
cmyname1
Feb 19, 2015 08:38 PM
maybe2fast
Feb 5, 2015 05:14 AM
ch3vyb1gbl0ck
Jan 28, 2015 04:45 PM
guionM
Sep 5, 2002 09:20 AM
