Autocross and Road Racing Technique There is more to life than a straight line
Can I JUST do lowering springs??
Old Jan 28, 2003 | 06:25 PM
LS1C5's Avatar
I have a '98 SS convertible and want to lower the car to improve looks. Can I just put a set of springs on the car without any harm??
What would be the disadvantages of this?
Thanks in advance.
Old Jan 28, 2003 | 07:02 PM
Dr.Mudge's Avatar
The disadvantage would be a mismatched combo of spring/shock rates. This could result in, poor handling, possible bottoming out, and also possibly dangerous. Its at least better than torched springs though.
If you have DeCarbons, they are only rated for 30k miles before replacement, and they dont soak up much spring in stock form, much less less travel and higher spring rates.
Old Jan 28, 2003 | 09:01 PM
rskrause's Avatar
Moderator
I used Eibach springs and stock shocks for three years and found it to be an enjoyable combo. No problems. And need I say that I drive hard?
Rich Krause
Old Jan 28, 2003 | 11:13 PM
Dr.Mudge's Avatar
Its been done, Brent Franker thought it was an ok setup too, I myself dont like mismatched stuff on paper or in reality. But, I have not ridden in a stock shock/heavy spring Camaro either.
Dont go too low, or the shocks wont absorb anything and you'll just bottom out and bounce everywhere. Does this sound familiar? Yep, you see Honduhs on the freeway like this every now and again. Bottoming out at speed is flat out dangerous, my 240Z was doing that due to one of the idiots who owned it before me. The car would like to go sideways around 100 when hitting a bump, not safe at all. If that former owner is still alive, some rice boy needs a kick in the pants.
Old Jan 29, 2003 | 07:16 AM
Norm Peterson's Avatar
Re: Can I JUST do lowering springs??
Easier to get wheelspin if you don't also do the rear LCA relocating brackets (weld-on's strongly recommended vs bolt-on's). Do a search in this forum on "anti-squat" (or maybe just "anti" is enough) for lots more info.
Norm
Old Jan 29, 2003 | 07:17 AM
Jarrod Sinn's Avatar
Dr. Mudge
What shocks would you suggest should be matched with the lower springs?. Do you think there should be any other suspension mods to make this a good combo?
Old Jan 29, 2003 | 09:35 AM
Dr.Mudge's Avatar
Without knowing the spring rates, you can't really get a good idea what the shock rates need to be. Adjustables help fix that, but are more than revalved shocks.
Rear LCA brackets at minimum.
Old Jan 30, 2003 | 06:33 PM
LS1C5's Avatar
Thanks for the feedback guys!
Noenav
Mar 1, 2019 07:38 AM
thenewkid
Apr 12, 2015 07:42 PM
ModdedNerd
Dec 25, 2014 05:51 PM
Dec 1, 2014 08:08 AM
thenewkid
Nov 27, 2014 09:41 AM
