Autocross and Road Racing Technique There is more to life than a straight line
Bilstein shocks,... why?
Old May 30, 2003 | 04:17 PM
Durbn4duke's Avatar
Will they stop the hard slamming in the rear when i hit a bump,.... that isnt even always that bad. i have a 2" drop.
Old May 31, 2003 | 12:53 AM
PaulN64's Avatar
I would look into adjustable shocks. I think it's better b/c then you'll be able to tune your ride the way you wan it. I've got KYB AGX on mine and they are great.
Old May 31, 2003 | 02:03 AM
BMC95TA's Avatar
I was thinking the same exact thing, however I was advised by alot of people over lt1 tech that if I was looking for ride quality then the bilstein hd were the best most economical way to go. Shortly I should be picking up a set.
PS. Isn't this the wrong forum, I think you want a tech section not GP section.
Old May 31, 2003 | 09:14 AM
PaulN64's Avatar
very true I guess my point is that you are stuck with what ever damping rate the shocks are set at and we all know everyone has their own preference. Not saying that Bilstien aren't good shocks but I would prefer to have options
Old May 31, 2003 | 12:34 PM
BMC95TA's Avatar
Yeah you are stuck with the rate which the bilsteins come with and that is from what I hear the only major downfall. It really comes down to:
1- are you going to be daily driving with occassional drag racing?
OR
2-are you going to be drag racing with occassional daily driving?
if its 1 go with the bilstein hd, but if its 2 I think you gonna want a shock that can be adjusted like HAL or KYB.
Old May 31, 2003 | 06:33 PM
FastGuyJR's Avatar
Durbn:
The hard banging in the rear when you hit bumps is probably due to your control arm bushings being worn out, not a bad shock. This was the exact problem with my car and was solved with replacement control arms with polyeurethane control arm bushings.
JR
Old Jun 1, 2003 | 08:01 PM
ZDriver96's Avatar
"Bilsteins.... why"
Because when your going 90 down a bridge and a semi tire falls off you better hope your car can handle well.
have sam strano revalve your bilstein hd's for your 2inch drop
Old Jun 2, 2003 | 06:16 AM
Durbn4duke's Avatar
Thanks guys, whos sam strano? sorry about posting it in here too, i thought i was on lt1 tech. my bad.
Old Jun 3, 2003 | 08:52 AM
bruecksteve's Avatar
Sam is the SCCA E Street Prepared and Pro Solo F Stock National Champion. Sam knows his F-Body suspensions. Give Sam a call. You'll be impressed with the time he takes to talk to you to figure out your exact needs. You won't be sorry. Go to Stranoparts.com
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
MDZ28
11
Sep 24, 2015 09:15 AM
KYWes
Aug 10, 2015 07:03 PM
