Autocross and Road Racing Technique There is more to life than a straight line
Baer PBR calipars noisy?
Old Jun 18, 2003 | 02:01 PM
mastrdrver's Avatar
I was wondering if anyone else is running these and have a lot of noise just driving down the road? You can hear the calipar bouncing around in the bracket just driving down the road when you go over the smallest bump. Are they suppose to be this noisy?
Jeremy
Old Jun 18, 2003 | 04:01 PM
JasonL's Avatar
If you are talking about the same PBRs as the C4s and Cobras... no, they should be quiet. I say 95% chances are that you're missing the anti-rattle clips that attach to the pads. Most aftermarket pads don't include them. If you can grab the caliper and move them up/down within the bracket, that's your problem.
My understanding is you can buy the clips at Carquest, NAPA, and Advanced Auto. Make sure you look at them before buying.
Old Jun 18, 2003 | 09:22 PM
I CORNER's Avatar
If it is worth anything, I use the BAER C5 PBR calipers, which are different than the PBR or PBR2s, and there is no noise or rattle.
Old Jun 20, 2003 | 04:33 AM
mastrdrver's Avatar
They dont move up and down, but they move left/right. Apparently the calipar sits in a bracket and moves side to side and follows the rotor to reduce changes of warping the rotor. It is the PBR 2 piston calipar on 12" rotors.
Where do these anti ratle pins suppose to go? I only have 1 clip and it holds the whole calipar in the braket.
Old Jun 20, 2003 | 11:24 AM
Ken S's Avatar
Check out this pic.. The antirattle clips are #2
Hmm, you know, its been a while but I i just noticed #11, but don't distinctly remember foolingw ith ti.. I guess it was already clipped on my stock assembly when I did my pad and rotor change..
Old Jun 20, 2003 | 01:34 PM
JasonL's Avatar
I'm still not totally clear what calipers you have, PBR makes both the C4/Cobra and the LS1/C5 style. Both are twin piston and have 12" versions. From your description it sounds like the C4 style.
Anyways, if these look like yours, the anti-rattle clips are circled in blue. They clip onto the pads.
Old Jun 20, 2003 | 01:54 PM
mastrdrver's Avatar
JasonL, that looks exactly like mine, except it says Baer. Does anyone have a part # for those ratle clips? I know I definatly dont have those.
Old Jun 20, 2003 | 02:22 PM
JasonL's Avatar
I don't have part# but check for "brake parts kit" (or similar) with the stores I posted above. The clips are sort of an S-shaped piece of metal, you need 4, one per pad.
z28newbie
Sep 9, 2015 10:26 AM
z28newbie
Larnach
Mar 22, 2003 10:20 PM
kandied91z
3rd Gen / L98 Engine Tech
Dec 12, 2002 02:07 AM
