will these wheels fit ok??
Old Feb 12, 2004 | 09:07 AM
Mustang4Lunch2's Avatar
hi i was looking at a set of wheels and found their fitment numbers and all that and since i don't know what fits i was wondering if someone could tell me if they would fit my 94 trans am, it's a t-top car btw. also if they will what kind of lip would i be looking at?? thanks again. please let me know if any of them would fit.
Size Disc Offset Hole P.C.D.
19x7.5 low +53/+48/+43 5 114.3
High +33/+23 5 114.3
19x8.0 low +45/+38+25 5 112/114.3/120
High +33 / +23 5 112 / 114.3 / 120
19x8.5 low +45/+38/+30 5 112 / 114.3 / 120
HIgh +40/+33 5 112/114.3/120
19x9 Low +45/+38/+31 5 112/114.3/120
High +45/+35/+20 5 112/114.3/120
19x9.5 Low +45/+38+31 5 112/114.3/120
High +45/+33/+13 5 112/114.3/120
19x10 Low +45/+38 5 114.3
High +18 5 114.3
Old Feb 13, 2004 | 12:40 PM
ttt come on does anyone know??
Old Feb 14, 2004 | 12:39 PM
Not sure what "low" and "high" means in those specs, and appears they are offering a variety of offsets, and different bolt hole patterns.
If the last number in each spec is the bolt circle, none of them are correct for an F-Body. You need 5 bolts on a 4.75" (120.65mm) diameter circle. You appear to have some 120mm bolt circle wheels in there, and they are typically for BMW's. Some people use BMW wheels on 4th Gens, but I personally do not recommend it. Strongly recommend you get the correct bolt circle.
You list some 7.5" wide wheels.... definitely not recommended. They are narrower than stock and will force you to use a very narrow tire.
A general guideline of offsets for various width wheels:
8" wide - 38 to 55mm
9" wide - 48 to 55mm
9.5" wide - 49 to 56mm
10" wide - 45 to 55mm (rear only)
10.5" wide - 45 to 55mm (rear only)
11" wide - 50mm (rear only)
mschmidt33
Mar 15, 2015 07:20 PM
Moshbmx1
Jan 20, 2015 03:27 PM
globalprojeff
Dec 6, 2014 04:18 PM
globalprojeff
Wheels and Tires
Dec 6, 2014 04:09 PM
Dec 4, 2014 11:56 AM
