will it fit?
Old Mar 21, 2004 | 12:09 AM
RS96Silver's Avatar
Question will it fit?
Ok guys im thinkin about gettin the black ZR-1 wheels...they r 17x9.5 in the front and 17x11 in the back....will i have a problem with rubbing or anythin like that?
Old Mar 21, 2004 | 07:15 AM
They will only "fit" if you get the correct "offset"..... generally, you want the 17x9.5 56mm fronts and 17x11 50mm rears. Some people claim to be able to bolt the 17x11's right on with no problems, no rubbing. I suspect is depends on the actual size of the 315/35 you put on the back. The Nitto DR's for example are narrower than the BFG DR's, so less chance of rubbing. With the BFG's I had to hammer the inner fenders a little. You will also need to look at the corner of the jounce bumper bracket. It won't hit the wheel at normal ride height, but if you jack the car, the bracket can catch the inside edge of the rim.
You might want to try a "search".... I know there have been several threads on this subject, and people, including myself have posted photos of any mods and the end results.
Old Mar 21, 2004 | 07:52 AM
Brent94Z's Avatar
Super Moderator
Hey Fred, one of these days we should just put together a page with all the stuff we normally type out and then just post the link... would be easier on the fingers hahahaha
Apr 3, 2015 10:54 AM
mschmidt33
Mar 15, 2015 07:20 PM
Jan 23, 2015 01:13 PM
TheGreenZ28
Exhaust System
Dec 6, 2014 10:23 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
