Will 1993 Gauge Clusters work in a 1994-1996 car?
Old Jan 13, 2009 | 06:16 AM
6LITEREATER's Avatar
I have a friend who was going to put a 1993 cluster in his 1994 Trans-Am. I was worried because I know putting a 1998 cluster in a 1999+ car causes smoke and since the 1993's used speed density and also temp gauge was different I was worried it would be a problem.
Has anyone ever switched one way or the other? I thought maybe a 1993 Camaro guy with the yellow numbers may have switched to the 1994+ white number style and could shed some light on this... Thanks.
Old Jan 13, 2009 | 06:39 AM
Kris93/95Z28's Avatar
Wouldn't it just be smarter, cheaper, and more simple to use an overlay with the 1993 font and colors in his 1994?
Old Jan 13, 2009 | 02:41 PM
Has nothing to do with any of that. A friend bought a 1993 150mph cluster (by mistake, thinking it was for a 1994) to upgrade his 1994 120mph cluster (he has a Trans-Am).
The overlay part we're not worried about as I made a new one for him...
Old Jan 13, 2009 | 02:43 PM
Wait, wrong one...
Old Jan 13, 2009 | 02:47 PM
^^That's not it either, looks the same but for a 1994 (no digital odometer). Regardless, you get the point. I'm not worried about aesthetics on his car, just wiring being different inside the cluster...
Old Jan 13, 2009 | 05:59 PM
The main difference is the source of the tach signal. 93 takes the signal from the coil, via a "filter". 94 and up gets the tach signal from the PCM. You will have to make sure they are compatible. The coolant temp difference would appear to mainly the temperature they printed on the left hashmark (100 for the 93, 160 for later models). I don't think the signal or the gauge operation are any different, just the markings.
Old Jan 13, 2009 | 07:23 PM
MILESF's Avatar
Smile
I don't know about a Trans-Am but, I replaced my 94 Camaro cluster (115mph) with a 93 cluster (150mph) because I wanted the yellow markings. No problems at all. Works fine.
Old Jan 13, 2009 | 07:59 PM
Awesome, thanks everyone! Sounds like at least we can give it a shot without worry of it smoking, lol!
Old Jan 14, 2009 | 01:00 PM
neil350's Avatar
It wouldn't cause an issue like that, I tried a 97 cluster in my 93 and for the exact reason Fred said, the tachometer wouldn't work past 2K rpm. Other wise, seemed to work fine.
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
Sarahrope64
Nov 27, 2014 11:17 AM
USAirman93
Nov 24, 2014 03:37 PM
Snoman73
Nov 17, 2014 07:22 PM
