White face gauges
Old Feb 9, 2006 | 08:21 PM
rsracing94z's Avatar
White face gauges
Has anyone here ever installed white face gauges on a 93-97 camaro? Was it very hard and whats the best way to go about doing the install?
Old Feb 9, 2006 | 08:43 PM
MAGIC Z's Avatar
Re: White face gauges
i did mine just face all the needles up and slide them down slowly and careful only takes a few mins
Old Feb 10, 2006 | 01:43 PM
TraceZ's Avatar
The tricky part is getting the needles back on in exactly the same places.
I did all but the speedometer by taking close up before pictures with my digital camera. I took the pics with the engine cold and the key on, but without the engine running.
For the speedometer, I used a handheld GPS to get my cruise control set at exactly 60mph. I then had a friend hold the wheel as I put the needle on at exactly 60.
If I was doing it again, I'd do the fuel gauge a little differently. I'd just fill the tank to the top, and stick the needle on at Full.
Old Feb 10, 2006 | 03:21 PM
MAGIC Z's Avatar
i ve done 5 sets and never have i removed the needles
Old Feb 10, 2006 | 04:01 PM
TraceZ's Avatar
It depends on what kind you are installing. On some you have to remove the needles, on others you dont.
Old Feb 11, 2006 | 08:38 AM
What is different in the ones you have to remove the needles on and the one you slide over the needles? Just the size of the holes?
Old Feb 16, 2006 | 08:35 PM
93hpz28's Avatar
between my father, brother and I. None of us had to take the needles out
Old Feb 16, 2006 | 08:40 PM
TraceZ's Avatar
correct. Some overlays have holes in them big enough to fit over the needles, on other overlays they are smaller and require you to remove the needles.
High HP TA
Sep 6, 2002 08:00 PM
AW/whiteZ-28
Aug 27, 2002 12:53 AM
AW/whiteZ-28
Aug 22, 2002 11:53 PM
slothgrant
Aug 22, 2002 03:01 PM
ollie-99
Jun 20, 2002 08:55 AM
