Where to run lines threw the firewall?
Old Dec 13, 2006 | 02:20 AM
BlackBird97's Avatar
I am just curiouse how to run lines threw the firewall? Where are all the openings located. Thanks!
Old Dec 13, 2006 | 06:57 AM
6SpdLT1Z's Avatar
there is a graumet behind the pcm and it comes out under the ps of the dash.
Old Dec 13, 2006 | 07:47 AM
CamaroRacing12's Avatar
yep! thats where i ran my LED Underglow wiring through!
Old Dec 13, 2006 | 08:06 AM
As usual, Shoebox has the info you need, regarding the grommet behind the PCM:
http://shbox.com/fw/Firewall_wire_feed.html
If you need something on the driver's side of the firewall, I can post a photo of where you can drill a hole, from the inside of the car, ending up behind the power brake booster.
Feffman
Oct 9, 2015 05:42 AM
Jazsun
Dec 29, 2014 12:14 PM
squarehead
Nov 21, 2014 08:02 PM
