Wheel cleaning
Old Dec 18, 2013 | 08:34 AM
Chet1185's Avatar
Wheel cleaning
Traded my stock TA wheels for these. Not sure how long they have been sitting with this grime on them but i need to clean them. Whats the best stuff to use?
Anyone know what american racing wheels these are? They are 17" with 245/45/17 tires.
Sent from my LG-LS860 using Tapatalk
Old Dec 18, 2013 | 08:35 AM
Chet1185's Avatar
Re: Wheel cleaning
Old Dec 18, 2013 | 09:48 AM
Re: Wheel cleaning
Torq-Thrust 2.1?
http://www.tirerack.com/wheels/Wheel...ish=Bright+PVD
Old Dec 18, 2013 | 10:40 AM
Chet1185's Avatar
Re: Wheel cleaning
Fred, i did notice on AR website that there are different finishes. How can i tell if these are chrome or polished?
Also, any ideas on cleaning them?
Old Dec 18, 2013 | 01:22 PM
Re: Wheel cleaning
Chrome will generally stay "shiny". Polished, if not clear coated, will oxidize and discolor, particularly if exposed to salt on winter roads. My guess would be polished, without clear coat. But it's not obvious from the photo.
Get some Mother's Billet Metal Polish, use a soft rag, and see what comes off. I doubt it will do a lot, but it may clean them up a bit. After that, you will need to invest in polishing equipment.
Old Dec 19, 2013 | 09:09 AM
Chet1185's Avatar
Re: Wheel cleaning
I have been reading that steel wool and cleaner works well. Anyone tried this before? Im pretty sure they are polished aluminum.
Old Dec 19, 2013 | 10:53 AM
Re: Wheel cleaning
I never tried steel wool. I've always used increasingly fine wet sandpaper and then buffing compound. If you google "polish aluminum wheels with steel wool" you get mixed results. Most of the negative comments relate to leaving some steel particles behind which will corrode, induce electrolysis and possibly cause scratches when the wheels are polished the next time.
Old Dec 21, 2013 | 09:28 AM
Chet1185's Avatar
Re: Wheel cleaning
This is after using eagle one chrome cleaner and a soft bristle brush.
Old Dec 21, 2013 | 11:49 AM
Re: Wheel cleaning
So you determined they are chrome, and not aluminum?
Old Dec 21, 2013 | 12:38 PM
Chet1185's Avatar
Re: Wheel cleaning
No i think they r polished. I will polish them up after cleaning and if i cant, i will get them powdercoated. Either way they were a good deal for my stock wheels.
Old Dec 22, 2013 | 03:01 PM
Mr99SS's Avatar
Re: Wheel cleaning
My lil brother handed my dad the eagle one mag cleaner he put it on his clear coated aluminum wheels now they look milky white
Old Dec 25, 2013 | 02:15 AM
Chet1185's Avatar
Re: Wheel cleaning
I think you have to be careful which one you use. Probably ate into the clear coat.
Old Dec 25, 2013 | 08:19 AM
parkers Z28's Avatar
Re: Wheel cleaning
Next time your at a gun shop pick up a can of " SAFARILAND BREAK FREE C.L.P "
Its not going to fix the faded clear coat but it will take the dullness out the milky look
HarleyZ28
Oct 5, 2015 06:23 AM
shroyvin56
Apr 3, 2015 08:15 AM
dpw21562
Jan 6, 2015 12:03 PM
