What can I do to "restore" my pcm?
Old Jun 13, 2006 | 12:16 PM
Crazy95Z's Avatar
Hey guys,
After 12 years, my pcm is looking quite old. And right now, I'm cleaning up my engine bay before the next motor goes in. I've painted a couple of things and those have turned out great. So I was wondering, can I paint over my pcm or is there some other way to clean it up? Thanks guys.
Old Jun 13, 2006 | 05:55 PM
Brent94Z's Avatar
Super Moderator
Re: What can I do to "restore" my pcm?
I've seen what looks to be a polished PCM. Lots of work but looks good!
Old Jun 13, 2006 | 10:37 PM
RacingTiger04's Avatar
mhm it can be polished but its a pita.. i half-way polished mine lazily while it was out for the m6 swap before i shipped it. really crappy job but looked better than before cause it took most of the age off lol. I think it could be painted pretty easily too, just go like ur painting any other metal. but be sure to cover the vents on (im gussing the knock module?)
Old Jun 14, 2006 | 01:42 AM
thesoundandthefury's Avatar
Originally Posted by Crazy95Z
Hey guys,
Buy a sheet of 0.24 guage 304 stainless steel, measure the length and width of the exposed end of the PCM, and cut the sheet with the corresponding measurements into the shape of a "plus" sign. Then find a machine shop that has a sheet metal brake that can bend the arms of the plus sign down into a box shape, and use it to cover the exposed end of the PCM. Oh yeah, be sure to polish it too.
If the idea of bending sheet metal puts you off, an alternative would be to buy a sheet of black plexiglass, cut the 5 sides of the cover out with a Dremel or radial arm saw, and epoxy them together. Then, paint it with this :
http://www.spazstix.com/xcart/home.php?cat=355
Won't be quite as durable as a stainless cover, but a little easier to make. Oh yeah, and a nice finishing touch for a little project like this would be to set it off with one of Brent Franker's vinyl decals. Maybe something that says "LT1" or "Z-28."
Old Jun 14, 2006 | 02:00 AM
Wait hold up a sec I almost forgot about something: Brent Franker sells chrome vinyl sheets. Maybe an even easier way to do this would be to just cut out the box panels from plexiglass, epoxy them together, and then use the mirrored vinyl with an X-acto knife and cut it out to cover the box. It would probably be alot easier if you just cut the vinyl to rough measurements and then when you stuck it on the cover you could trim the excess off as you go. You could probably do this project for about <$30.
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
fift5
11
Oct 1, 2015 10:31 AM
drt
Sep 27, 2015 04:39 PM
MDZ28
11
Sep 24, 2015 09:15 AM
