VERY unique Navigation install *pics inside*
Old Apr 6, 2004 | 11:52 PM
JTS95TA's Avatar
Well guys I did something probably no one has ever done before with some success so far. I purchased a Chrysler RB1 in dash navigation unit (made by alpine for chrysler). It took some dremeling and special wire harnesses top get it to work but its in place and looks AMAZING. Only problem is after buying it and installing it I found out this unit uses a special PCI-bus input wire which allows it to get vehicle speed info and possibly other info that I cant seem to duplicate from my camaro. I believe this single wire comes from the cars body control module and is digital. Hooking my VSS wire to the bus wire going into unit will not do the trick. The map will only show my turn and no movement. So for now voice guidance and mapping isnt working. If there are any of you out there that are VERY knowledgeable with vehicle electrical systems and more specifcally mopar systems I need your help BAD!!! Anyway here are some pics let me know what you think.
http://www.gooterbash.com/forums/uploads/images/230.jpg
http://www.gooterbash.com/forums/uploads/images/228.jpg
http://www.gooterbash.com/forums/uploads/images/229.jpg
Old Apr 7, 2004 | 12:30 AM
6Speed's Avatar
Awesome man! I wish I could help you, but I don't know much about electronics.
How much did it cost ya?
Old Apr 7, 2004 | 12:42 AM
chesee48's Avatar
very sweet lookin! i hope u get it to work out ok.
good luck
Old Apr 7, 2004 | 12:43 AM
Pandamonkey's Avatar
I also will not be any help.
Just wanted to say - nice looking install!
camaro322hp's Avatar
very very nice. i used to hate these until i drove my buddy's 330i with a nav system. i could really get used to having one of these in my Z.
wish i could help you more. i'm sure you're already aware of this, but when i was re-doing my stereo system, i seem to recall a green wire that sent a speed signal that was used for the 'speed compensated volume' on the stock deck...
Old Apr 7, 2004 | 12:54 AM
JTS95TA's Avatar
yup and that signal is analog and does nothing when hooked to the PCI-bus wire going to the navi unit. I paid a little over $1000 for the unit brand new came with manual, GPS antenna, and the latest navigation DVD software. The install went so well I really dont wanna turn around and sell it :-( still hoping there is a way.
Old Apr 7, 2004 | 01:04 AM
bigdreamZ's Avatar
Wow that looks really clean, does it play mp3s? I see it says DVD on the side can you watch DVD movies on the screen? Anyways hope you get the problem fixed...
Old Apr 7, 2004 | 09:12 AM
JTS95TA's Avatar
No it does not play MP3's, and it does not play DVD movies either. It is a DVD-rom and infact some systems such as ones in BMW's there are ways to get it to play the movies. Havent yet researched to see if you can with this unit.
Old Apr 7, 2004 | 09:28 AM
94BlackBowtie's Avatar
That looks like an extremely nice and clean install!
I really hope you can find out the answers to your problems - I would hate it for you if you had to remove it or anything of the sort.
You may want to post about it here...most of the people there are very knowledgable. There may even be other sections of that forum that could help you out.
Old Apr 7, 2004 | 09:30 AM
Brent94Z's Avatar
Super Moderator
To my knowledge, you will not get the VSS out of the BCM.
What you might be able to do is make your own. What I mean by that is figure out what kind of signal the unit needs. Just as a rough example, you would then put a piece of foil/reflective tape, whatever on the wheel. The sensor would mount to something on the front suspension and pick up the foil/reflective tape and send this back to the unit. That is a very rough idea but might work. Just need to find out what the signal is that the unit is looking for.
Old Apr 7, 2004 | 10:25 AM
JTS95TA's Avatar
Well the navigation unit gets a digital signal via one wire (PCI-bus) that comes from the body control module (I think). So I was thinking that since obviously my Camaro has a VSS wire and one that actually goes to the stock CD player for speed controlled volume, maybe I can convert that analog signal to digital which the RB1 navi might be able to understand. Does anyone know if they make such a converter?
Old Apr 7, 2004 | 10:42 AM
This Google Search yielded quite a few results...
So did this one... (spelled wrong)
You might want to take a look at the sponsored links to the right as well!
Old Apr 7, 2004 | 10:46 AM
Jilly's Avatar
I'm no help here either. I just wanted to say neato.
Old Apr 8, 2004 | 12:54 PM
joed4640's Avatar
very nice install & Z
This may help you if you decide to ditch your curent setup
custom carputor install
I think he paid around $1500, but he has everything a stock sterio and a P.C. offers in his jeep (radio,cd,dvd,mp3,internet & of course, navigation with all the goodies) the possiblities are endless....
the thread has everything you will need to install, i cant wait untill i have $1500 to spare
...hope this helps as a solid plan B!
Old Apr 8, 2004 | 03:35 PM
Tair's Avatar
that's a nice fit
