Urgent, help with clear corners!
Old Jun 11, 2007 | 07:21 PM
NiteRider's Avatar
Guys, I don't know what GM was smoking when they designed this part of the camaro but taking these things out is a PITA!! I can't get them out, i've removed the headlight and all, I have clear access to it but on the side of the bumber/fender is that part that sticks out, it just won't let you squeeze in or out the corner light! What have you guys done at this point? Someone please shed some "light" on this for me! Thanks!
Old Jun 11, 2007 | 08:19 PM
AZ2ENVY's Avatar
There is 3 7mm bolts that hold each lense in the bumper .
Two of the 7mm bolts are on the side facing the car and one 7mm bolt holding the bottom of the lense in the bumper . Hope this helps
Old Jun 11, 2007 | 08:52 PM
NiteRider's Avatar
It didn't, but thanks anyway. I'm done! My problem was the part where the bumper attaches to the fender, really, GM, what were you thinking??
Thanks anyway, AZ2ENVY
Old Jun 11, 2007 | 09:35 PM
custom95's Avatar
I take it you got the clear corners I sent?
Old Jun 13, 2007 | 07:01 PM
LastBreedLS1's Avatar
im thinking of getting some clear corners myself. is it really that hard to remove them. any tips before i try to remove them?
Old Jun 14, 2007 | 11:30 AM
one wicked element's Avatar
They are a bitch, my car did the same thing.
I pushed the big side towards the foam bumper, and pulled the bumper to me a little. Then, I went inbetwen the two screws on the fender. It's a VERY tight fit. I chipped my yellows one the first them. Since then, I went from clears to smoked with no issues.
Pull the bumper towards you (it's hard to describe) to give you a bit of room.
You'll be fine.
Old Jun 15, 2007 | 07:44 PM
snakeatinZ's Avatar
What are you guys talking about?????? I can put them in blindfolded... seriously. Are you taking them out from the top? Remove the plastic trays on the underbody and everything is right there.
Steve
Old Jun 15, 2007 | 08:52 PM
fasteddie94's Avatar
Steve
And it's a helluva lot easier than pulling the head light and dealing with all that mess from the top.
Old Jun 16, 2007 | 03:20 AM
1BigBird3's Avatar
Rest assured it's cake going from the bottom. 3 plastic push pin screws, bend the flap, and you'll have plenty of access.
Goodluck!
Ruben F.
Old Jun 16, 2007 | 10:50 AM
j1shotz88's Avatar
were goggles if you go from underneath the car to help keep crap comin in your eyes
Old Jul 29, 2007 | 09:49 PM
IROC Z 350's Avatar
I can't seem to get the small corner past that steel lip inside the fender! I'm seriously considering removing the headlight assembly.
Old Aug 2, 2007 | 05:22 AM
Craddock's Avatar
I changed it out on the fly just to pass for a sticker. All you've got to do is take it from the bottom like stated above. Use a flashlight if you need to so you can see inside the fender.
Old Aug 2, 2007 | 09:13 AM
94_PatriotRed_Z's Avatar
If you guys notice all the people who are having trouble own LS1 bodystyles and everyone who says its easy and to do it from the bottom own LT1 bodystlyes. I know on an LT1 its real easy to do it from the bottom, but maybe on an LS1 its hard.
Novo
Jun 14, 2016 02:58 AM
PopoFormula
Oct 12, 2015 04:19 PM
HAWG
Sep 25, 2015 11:41 AM
tommalcolm
Sep 11, 2015 03:39 PM
