t-top leaks
Old Dec 20, 2010 | 08:24 AM
edgarda2's Avatar
t-top leaks
can somebody tell me how to stop leaks on my t tops cuse when it rains an it sit the car for a while it gets wett badd
Old Dec 28, 2010 | 10:08 PM
crazypurgatory's Avatar
Re: t-top leaks
Try this.
https://www.camaroz28.com/forums/sho...=494368&page=3
Old Dec 29, 2010 | 06:02 AM
edgarda2's Avatar
Re: t-top leaks
thanks
Old Dec 29, 2010 | 09:43 AM
96 Z 28's Avatar
Re: t-top leaks
Are you sure it's the T-Tops??
If there's water in the rear floor wells, then most likely it's overflowing the hatch sills and running down underneath the rear seat.... Not a T-Top Problem
Thread #1
Thread #2
Old Dec 29, 2010 | 01:13 PM
edgarda2's Avatar
Re: t-top leaks
no the water is on the passenger seat
Old Dec 29, 2010 | 01:14 PM
MustangEater82's Avatar
Re: t-top leaks
btw here is a post I just posted in...
https://www.camaroz28.com/forums/sho...d.php?t=494368
Old Dec 29, 2010 | 01:58 PM
Whitefish's Avatar
Re: t-top leaks
I used to have an 87 with ttops that leaked really badly. I smeared the whole rubber seal area with Vaseline & it kept the water out. I had to redo this every few months & it does make kind of a mess if you are not careful, but it did stop the leaks. Good luck.
Old Dec 29, 2010 | 06:29 PM
edgarda2's Avatar
Re: t-top leaks
wat if i used the GM
leak stopp
is it any goodd?
Old Dec 31, 2010 | 07:15 PM
TT350's Avatar
Re: t-top leaks
My 96 T/A leaked bad. After messing with the T-Tops it still poured.
On day I had enough, I put my son on the water hose and I got in that car.
Come to find out the windshield leaking.
Took it to the glass shop to get the windshield replaced and 75% of the urethane had come loose from the windshield frame.
The guys where able to remove it and clean all the urethane off that reinstall it.
Jeff1904
Jun 5, 2016 05:00 PM
colts0455
Sep 27, 2015 01:07 PM
Z Power
Sep 19, 2015 11:19 PM
rideordie
Sep 7, 2015 08:22 AM
