Strut Bar on 2002 Camaro V6
Old Apr 1, 2011 | 05:49 PM
mybadd02camaro's Avatar
Question Strut Bar on 2002 Camaro V6
Hi All,
Does anyone know where to pick up the attachments to bolt on the strut "slp" bar in a V6 2002 Camaro??
I have purchased just the bar but don't know where I can bolt it to and where the attachments can be purchased.
If anyone has installed one can I see a picture to see where to bolt it to.
Also is the bar cause trouble for changing/adjusting things in the motor?
PLEASE let me know!
Thanks!
Old Apr 1, 2011 | 08:40 PM
TD95Z's Avatar
Re: Strut Bar on 2002 Camaro V6
Not entirely sure what you mean by attachments. The bar simply bolts to the shock towers. You remove the front two nuts from each shock mount, slip the bar on, and put the nuts back on. You may have to put a washer on each stud before the bar goes on. I seem to recall the SLP bar on my old car coming with washers. It doesn't cause any issues when it comes to servicing the vehicle, but even if it does, it's easily removed.
1996LT1Z28
Jan 14, 2015 08:09 AM
jeff94z28
Sep 11, 2002 02:01 PM
ChrisFrez
Aug 12, 2002 11:50 AM
AW/whiteZ-28
Jul 25, 2002 04:09 PM
