Short shifter A4 style
Old Jan 17, 2009 | 10:48 AM
1msfyter's Avatar
I loped off 3/4" off my A4 shifter My **** looks so much better. 15 min and a dremel and its very easy to do. Now its the right height to rest my hand. BTW thats a 2005 leather trailblazer SS ****
BEFORE: http://i280.photobucket.com/albums/k...8/CIMG0584.jpg
AFTER: http://s280.photobucket.com/albums/k...t=CIMG0634.jpg
Old Jan 17, 2009 | 08:51 PM
snorkelface's Avatar
Nice. Little touches make the difference.
Did the TBSS handle just thread on like a direct replacement?
Old Jan 17, 2009 | 09:03 PM
1msfyter's Avatar
The trailblazer handles comes with a leather shift boot also, which I removed. It uses a set screw in front, no U clip. Also it slides right on and only has 1 notch inside to alighn on the shift rod. The release **** sits offset on the rod also points back a bit(see pix)
http://s280.photobucket.com/albums/k...t=CIMG0636.jpg
Old Jan 17, 2009 | 09:09 PM
johnny6's Avatar
Looks good, i might try it out in the near future.
Old Jan 23, 2009 | 10:56 AM
irocbsa's Avatar
The push button start looks awesome! Do you mind sharing how you made it?
Old Jan 23, 2009 | 11:08 AM
irocbsa's Avatar
It looks like you used the S2000 switch. Did you bypass VATS to wire it, or do you still use the key to power up?
Old Jan 24, 2009 | 01:30 PM
1msfyter's Avatar
Left the VATS system intact. I have the relay ground hooked up to the brake pedal, requiring you to push the brake when starting. Its a showy thing but cool anyway. I used some ABS and fillled the hole where the cubby was. Easy to do.
link to push start install: http://bowlingss.com/Mods/InstalRepa...e%20Switch.mht
Old Jan 24, 2009 | 01:58 PM
Blownbird355's Avatar
lose the chrome button and the stripe
Old Jan 24, 2009 | 02:20 PM
RacingTiger04's Avatar
so do you still have to put the key in the car to start it? My altima had push button with no key.. and I must admit, I somewhat miss it, but how secure is it really? O_O.
Nice mod to the shifter too btw.
Old Jan 26, 2009 | 01:56 PM
irocbsa's Avatar
+1. I'm assuming you still have to turn the key to "Run".
Old Jan 27, 2009 | 07:24 PM
1msfyter's Avatar
Yep. Gauge cluster will soon be silver (Macewens) And the seats will be two tone silver and black
grabbem88
20
Dec 27, 2015 07:42 PM
Apr 16, 2015 09:57 AM
karpetcm
Feb 9, 2015 09:21 PM
xmatt
Sep 16, 2002 02:37 PM
