Shift stick thread adapters?
Old May 5, 2004 | 12:43 AM
rlax31's Avatar
Does anyone make adapters for the shift stick to fit ***** of other sizes on them?
I want to put a 12mm **** on our 16mm stick, am I SOL?
Old May 5, 2004 | 12:44 PM
JasonD's Avatar
Admin Emeritus
I'd kind of like to know this myself.
What kind of 12mm **** are you trying to put on? Do you think this might get better response in the Driveline forum?
Old May 5, 2004 | 02:27 PM
rlax31's Avatar
It's the Cobra 10th anniversary ****, carbon fiber (fabric feeling, no plastic covering the fabric, or fake-fiber look, and has an aluminum 6-speed pattern on the top)
A friend of mine has one in his mustang, just feels right in my hand, so I'm trying to find an adapter, or if it's reasonable to rethread my stick
Old May 5, 2004 | 03:29 PM
bellcamaro's Avatar
i don't know about this "adapter" thing.. you can always do some simple modifyin just clamp the thing down, drill a hole into where the 12 mm nut is, and (you have two options)
-go buy a 16 mm nut and set it in the hole with some glue
-go buy some threading compound, fill the hole up
then just twist your newly modified stick shift on...
shouldn't be that hard. unless you don't have a drill and boring bit.
Old May 5, 2004 | 05:26 PM
ShelbyZ28's Avatar
Damn that looks nice! Where can you get those at? I just might have to get one if someone knows how to get it to fit our shifters.
-Bryan
Old May 5, 2004 | 06:24 PM
97FormulaWS-6's Avatar
Do you have a stock or aftermarket shifter?
If you have an aftermarket, I'd have a machine shop turn the shifter down and re-thread the shaft.
If you have a stocker, I'd say you're outta luck.. although it's a great excuse to buy a Pro 5.0...
Old May 5, 2004 | 09:03 PM
Bud M's Avatar
Yeah, a machine shop should be able to handle turning the stick down to 12mm.
Old May 5, 2004 | 09:21 PM
JoeliusZ28's Avatar
hmmm, I might have to look into this. I have a craftsman lawnmower with a handle that would make for an awesome pistol grip ****. The thread is too small though.
...and yes, I would suffer using the lawnmower without a shift ****
Old May 5, 2004 | 09:28 PM
AW/whiteZ-28's Avatar
My friend just bought a anny. cobra It's sweet they have the CF shift boot too. I wanna get that
Old May 6, 2004 | 09:57 PM
95_LT1_6SPD's Avatar
i would have to see a picture of the bottom of that shifter, but would it be possible to drill the bottom out and tap it to size? Thats what i had to do to my t-handle.
Old Jun 25, 2004 | 05:36 PM
rlax31's Avatar
Here is what I'm considering:
1. Drilling out the ****, and either glueing a 16mm nut, or going with the threading compound, but where could I find threading compound? Home Depot?
2. Taking the stick to a machine shop and having them turn it down to 12mm, do you think it would cost much??
BLK1997Z28
May 2, 2015 01:26 PM
PROJECT X
Apr 17, 2015 12:13 AM
Apr 16, 2015 09:57 AM
Magenta_Hearts
Mar 30, 2015 09:42 PM
