Sham Wow
What's an MF towel? Most of the time i dry the car inside the garage for that same exact reason, i don't use alot of pressure while soaking up the water i just gently wipe it until most of the water is soaked up then i use the real fuzzy towel (maybe that's the mf towel?) to get the rest of the water.
I usually use a steady stream of water from the hose to rinse most of the water off in sheets after i wash the car, and then "dot" a towel on the spots where theres still water. I also dry the car in the garage. This works pretty good for me. You just have to remember that anytime you touch your paint with anything that theres a chance for marring...
