Scanmaster Mounting Spots.
Old Sep 9, 2006 | 05:35 PM
Bayer-Z28's Avatar
Like it says.. Where'd you mount your Scanmaster? I've got some mods lined up for next spring. Trying to make everything work in the interior as far as system monitoring. Any cool spots? Top of the steering collumn?
In the Camaro's, I've seen it mounted in place of the ASR switch, on the LT1's, usually mounted in place of the vent on the top of the dash.
Old Sep 10, 2006 | 02:46 AM
LT1 POWR's Avatar
Re: Scanmaster Mounting Spots.
I mounted mine in the middle air vent in my 96 LT1. It just looks like it belongs there. I get people saying it looks stock all the time. Here is a pic and the install guide i used. I dont know where you could mount yours since you dont have the same dash and vent. I have seen some people mount them above the steering column and it looks ok there, but not as good as the air vent. I have also seen some people mount it in the recesed area above the speedo and tach.
Here is the install guide for the air vent.
http://www.bfranker.badz28.com/fbody/scanmaster.htm
Here is the install guide for above the speedo and tach.
http://www.projecttransam.com/projects4.asp
Old Sep 10, 2006 | 12:43 PM
Bayer-Z28's Avatar
Ahh.. My gears r turnin.... GOt an idea. I don't use my top/ center vents... I could try to rig something up in there... Try to keep it round like the stockers..
Could stick a shift light in there like I wanted to. But I don't want it obvious or rigged.... Man I wish I had a WS6, those vents are purfect. Or the LT1...
Old Sep 11, 2006 | 07:29 AM
On top of the column.
http://www.injuneer.com/images/photo.../DCP04287a.jpg
Old Sep 11, 2006 | 02:09 PM
grandnational007's Avatar
Bayer, i see you post all the time on CTFBA...
I think you said you were back in CT now?
I figure I could fill you in...
gimme a pm
Old Sep 11, 2006 | 07:17 PM
Bayer-Z28's Avatar
Thanx guys!
Old Sep 11, 2006 | 08:23 PM
94_camm's Avatar
how does scanmaster work anyway?were can u buy it?
Old Sep 11, 2006 | 09:58 PM
LT1 POWR's Avatar
Here is a wonderful writeup brought to you be Injuneer.
http://members.aol.com/InjuneerZZ/ScanMast.htm
You can find them used on the board all the time or new here.
http://www.speedspecialty.com/store/...uct=scanmaster
Old Sep 16, 2006 | 08:05 PM
BMWKillR's Avatar
yea, mine is located in the air vent where LT1 POWR's is. I am still trying to figure this gadget out. I just got injuneer's user manual, but I am not getting any readouts at all. When the car is on, i don't see diagnostics going. I just hear it go beep beep when I turn the car off, so what gives?
Old Sep 16, 2006 | 11:42 PM
LT1 POWR's Avatar
I dont think they make noises. Well mine doesnt i dont think. Go through and check all of your wireing. Did you use the wires for the ALDL port to hook it up as seen here.
http://www.bfranker.badz28.com/fbody/scan23.JPG
Just make sure your wireing is correct.
Is it getting any power?
Old Sep 17, 2006 | 12:00 AM
01Z's Avatar
01Z
Originally Posted by Injuneer
I'm looking at your picture Fred; how is it attached? thanks.
I just bought one from Full Throttle last week....
Old Sep 17, 2006 | 08:10 AM
BMWKillR's Avatar
I pulled it out a little from the dash ans it has 1 white wire running to it. I don't recall ever seeing a cluster of connectors like in your picture. As for the power part, it definitely beeps I know that, so it must be getting power of some kind. I did not install it, it came w/the car. IDK if it was working at the time I bought the car I didn't know what it even did.
Old Sep 17, 2006 | 06:42 PM
LT1 POWR's Avatar
The scanmaster has 1 white wire comeing from it? If so thats just the outer protective sleeve and inside that there are 3 smaller wires. That cluster of connectors you are reffering to is down by the pedals.
Go through this install and make sure all the wires are makeing good connections to the correct location. I know one of my wires came loose and the scanmaster stopped working.
Old Sep 18, 2006 | 09:13 AM
Velcro.
From my online writeup:
INSTALLATION:
The ScanMaster is supplied with a 4-wire bundle (Note: I have heard that the latest models are missing the green wire). The wires have stripped ends, and that's it - no plug, no connector.
Red - +12V power supply. It does not have to be "switched" power. The ScanMaster will shut itself down on loss of signal. I used the wire that goes to the cigarette lighter.
Black - Ground. Connect this wire under any good screw or bolt that is securely mounted in the metal chassis.
White - Data wire. Connect to the "data" terminal in the ALDL connector. In the 94's this it the lower right hand pin. On all models, this is a light tan wire.
Green - Not used.
Some thoughts on the wiring details:
You need to provide for a "disconnect" on the white data wire. It must be disconnected if you attempt to attach any other device to the ALDL connector, like a laptop cable for LT1_Edit or other programming system, a cable for a Hypertech Power Programmer, or a dealer scan tool. The ScanMaster uses bi-directional communication, and the signals from the ScanMaster will interfere with the signals from the programmers or scanners. A small switch or a "plug" will suffice.
If you put a "plug" in the other lines, it allows the unit to be removed and used on another vehicle without cutting the wires.
The white wire does not have to be connected directly to the pin on the ALDL connector. I spliced into the wire on the back of the connector, and added a small switch.
I've never heard mine make any noise at all.
Old Sep 18, 2006 | 10:37 AM
01Z's Avatar
01Z
Velcro.
Thanks. I've pulled my instrument bezel because I was able to get the top pad up without breaking it. I'm undecided as to whether to cut my near perfect dash interior up to make a permanent installation. I might just put it all back together and go with the Velcro although I don't think the year of fbody I have has a good enough area over the column like your bird.
I would think the instructions would have some mention of a sound producing component. I guess it doesn't have to be a speaker....
BTW, the instructions say to connect to the "white" wire. You are correct in that it is actually a tan wire. There is a white wire (pin 5 I think) that has a black stripe on it.
