Sagging door
Old Oct 18, 2004 | 08:00 PM
Zrated383's Avatar
Sagging door
My driver's side door sags when you open it and then when it hits a certain point you can feel it drop a little more. How much do you think a body shop would charge to fix this because I'm pretty sure I can't do it? Also, the interior door panel on the same door is coming off...how can I reattach it?
Old Oct 19, 2004 | 10:26 PM
TA350's Avatar
Re: Sagging door
I used to have the same problem when I had my camaro. You have to take off the hinge and re weld it. It sucks to have that done but thats whats wrong. I never got it fixed just sold it like that.
Old Oct 20, 2004 | 12:02 PM
spawnz28's Avatar
Re: Sagging door
You may want to check the bushings in the door hinges because they probably need to be replaced. That's not uncommon for 3rd gen f-bodies. I had several 91 camaros that did that. you probably need to take it to a body shop though. About your door pannel, go to a junk yard and look for those plastic pieces that screw into the door pannel and pop into the door. Yours may need to be replaced.
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
WPHIG2
Aug 27, 2015 06:37 AM
