Removing & Replacing Headliner Help
Old Mar 20, 2007 | 12:29 PM
Blown 96 WS-6's Avatar
The headliner on my T-Top TA needs to be replaced. I have found sources for replacement headliners but I was wondering if the removal and replacement is fairly straight forward?
I assume that it is just held up with those typical interior panel push connectors but I'm not sure.
Has anyone done this who can give me some guidance? I don't suppose there are any pictures out there?
My project will be complicated by the 6-point roll cage. The top hoop comes within an inch or so of the headliner. That may make matters tough if it requires a lot of clearance.
Thanks for your help
Old Mar 20, 2007 | 02:00 PM
JAB's Avatar
JAB
If it's the same as the one in my Camaro then it is quite easy. I just removed the A-pillars, sun visors, the little hanging hooks on each side of the back seats, and the rear dome light. After that it's just held up behind the rear panels which you can bend down with the hooks removed and velcro in the middle of the T-Tops.
Old Mar 20, 2007 | 02:06 PM
That sounds very easy. Hmm, no clips or push pins or anything? That sounds like it will slip out between my roll bar without much difficulty then?
Thanks for the response!
Old Mar 20, 2007 | 02:11 PM
JAB's Avatar
JAB
I think you should be able to get it out rather easily. I think there may have been one of those plastic clips under rear dome light cover but I don't remember any other ones. I would suggest a second set of hands when putting the new one in so you don't have to worry about tearing or bending it too much.
Old Mar 20, 2007 | 02:15 PM
Good to hear. I will have my buddy help. We always work on our cars together ... second set of hands and eyes
Iamherefornow
Jan 26, 2015 04:57 PM
sscott
Jan 17, 2015 04:30 PM
ANDYZ28
Dec 29, 2014 09:13 PM
pologreen97z
Dec 2, 2014 10:42 AM
Darth Xed
Sep 4, 2002 12:56 PM
