Removing hatch defroster lines?
Is it possible to remove the defroster lines on the rear hatch of a '94 Z28? The window is going to be re-tinted and it looks cleaner without the lines. Plus, they're never used.
Re: Re: Removing hatch defroster lines?
Originally posted by ProjectRS
When did youget a 94?
PS why is your post count at 2?
And because of this thread. I enjoyed being at 2.
Originally posted by ibanez6rg
Ford has his own little *insert another word for female dog here*?
Apply hot wax and pull off. Hey it works for girls right... and they're complicated, also.
Actually, I didn't want to log out and log him in, so I posted it. Makes sense? Yes.
Does wax really work?
id say use a razor and some steel wool. get the majoity of the line off with the but be very cautious not to scratch the window then clean any leftover with the steel wool. i would also recomend removing the hatch to do this.
I did this to my 84 Z for the same reason.You can use a razor blade as stated above.It won't remove then completely though.The lines will be alot less noticable.The reason you can't remove them completely is that the glass is etched for the defroster grid.
Victor Lamb
Aug 26, 2017 02:52 PM
Jan 13, 2015 09:52 PM
squarehead
Nov 21, 2014 08:02 PM
GA93FORMULA
Jul 24, 2002 11:38 PM
