Removed Emblem, how re-apply?
Old Sep 22, 2004 | 04:38 AM
camarosource's Avatar
I removed the "Z28 25th Anniversary Edition" emblem on the dash and apparently once you remove it, that black double sided tape won't go back on.
I removed the black double sided tape from it so now it's just the plastic emblem.
I tried regular Double Sided foam tape and it would not even stick at all. In fact, the weight of the emblem dropped right off.
The tape I used was NOT 3M. Usually (I believe) emblem tape is 3M is it not? Anyone know exactly what double sided tape I need to buy to stick it back?
Thanks very much.
Old Sep 22, 2004 | 01:47 PM
Tair's Avatar
Re: Removed Emblem, how re-apply?
not sure what kind of TAPE you can use....but i believe you can buy automotive glue at any auto parts store. It's not supposed to damage paint when you apply it to the outside of cars.....so I don't think it would damage your dash either.
Old Sep 22, 2004 | 03:52 PM
SUPERSPORTBOY2's Avatar
3M 2 sided tape is the way to go like you said. that is what we use at work when we have to retape emblems.
Old Sep 22, 2004 | 11:11 PM
kingman109's Avatar
3M makes an adhesive which is paper thin - comes on rolls - u peel one side stick emblem to - then cut out with x-acto knife - peel other side and apply - stuff is insanely strong -
not sure where to get - i have industrial size roll cause i use it when flushmounting my design work for presentations
Old Sep 22, 2004 | 11:25 PM
Tair's Avatar
good to know...i'll go look for some of that tape too
Old Sep 22, 2004 | 11:33 PM
lookimatree's Avatar
I've seen stuff called emblem adhesive, that might help.
Old Sep 24, 2004 | 05:35 PM
LT1FUN's Avatar
I reapplied my emblems with some 3M emblem adhesive from Advance Auto Parts. Works great and is pretty easy to use.
Old Sep 24, 2004 | 08:45 PM
Great thanks guys!
Old Sep 24, 2004 | 09:58 PM
94Z28WP's Avatar
I used automotive GOOP on one of my emblems and also on molding on an older car I had... It never came off... Strong stuff.
marlar98
Sep 19, 2015 07:53 AM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
reww86
Aug 29, 2015 06:04 PM
4586
Jul 31, 2015 06:03 PM
Jlo
Jul 29, 2015 03:52 PM
