question about seats.
Old Aug 31, 2007 | 12:05 AM
BlkZ28Kreepn's Avatar
going to be picking up a pair of driver/passenger front seats for my car..The seats are coming out of a 2002 trans am, going to be putting them in my 94 camaro.Will i run into any problems, im getting the seats along with the railing..will they bolt right in?
Old Aug 31, 2007 | 05:22 AM
Patrick Davies's Avatar
No problem at all. The seats out of any 4th Gen ('93-'02) will fit. Direct bolt in. (They will also fit any 3rd Gen too, as the cars share the same floorpan). I assume the TA seats are power; if you want the bolsters to work, you will need the air tube to connect the two seats. You could buy that from a wrecker (it runs under the carpet, under the console between the two seats), and you will have to connect the power. If your car doesn't have a power drivers seat already, you will have some wiring to do. Just so you know, the TA drivers seat is power, while the passenger seat isnt. Both seats have to be connected together, with the air tube, for the bolsters to work. I put '95 TA seats in my old '87 IROC-Z, and they worked perfectly.
Old Aug 31, 2007 | 05:54 AM
blackrat's Avatar
Be aware the T/A seats place you a little higher than the Camaro buckets. I like mine though, well worth it.
Old Sep 1, 2007 | 02:09 PM
Good point. However, the seats out of the earlier years of the 4th Gen Trans Am (say, '93-'95) sit lower than the later ones. I had seats out of a '95 TA, and while the seats had power bolsters, all the other adjustments were manual. As they didn't have motors underneath them, they sat about 2" lower in the car. I also liked the adjustable thigh part that could be moved up and down. This piece is fixed in place, and not adjustable on the later cars (like my current '99 TA Firehawk).
jbrockwell
Mar 14, 2015 08:44 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Joes96z
Dec 14, 2014 04:03 PM
CamaroGuy719
Sep 16, 2002 04:58 PM
