POR-15 problems
Old Nov 12, 2007 | 04:35 PM
mdacton's Avatar
POR-15 problems
I bought the kit with the cleaners and everything in it.....
Used it on fresh bare sheetmetal and did 3 coats....the stuff peels easy. I can peel it with my finger nail. Should it be primed first or not?
I was pretty dissapointed in it
Old Nov 12, 2007 | 07:24 PM
fasteddie94's Avatar
The surface need to be fairly rough for it to stick. If you sanded it too smooth it may do that. Also depends on how quickly you put the other coats on. The bottom may not be dry enough. Hard to say really, I haven't ever had a problem with it.
Old Nov 12, 2007 | 07:27 PM
mdacton's Avatar
I didn't sand the metal at all.....it was new mild steel sheet metal..so it was smooth. Maybe I should sand it a little.
After the first coat I waited for about 10 hours til I put another on...it was dry to the touch..maybe I should wait 24 hours.
Old Nov 12, 2007 | 08:12 PM
thesoundandthefury's Avatar
If you don't want to sand the base metal down, you can use self-etching primer.
Old Nov 13, 2007 | 12:20 AM
MarcR94v6's Avatar
Almost all paints need some "tooth" to grab on to. Did it come with instructions?
Old Nov 18, 2007 | 06:42 PM
SevenStars's Avatar
It sticks alot better on rough surfaces. You can try sandblasting the part in question, reprep it, and it will stick. Just my .02
Old Nov 18, 2007 | 07:03 PM
mdacton's Avatar
well I used it on my firewall...so I can't sand blast it. I allready broke 2 windshields this year So I may just sand it....when I get around to it, I'm pretty lazy to be honest
Old Nov 19, 2007 | 10:43 AM
blackbirdta's Avatar
where did you get your por-15 and what exactly do you need? I'm going to use it on my 35's frame...
Old Nov 20, 2007 | 09:47 PM
SevenStars's Avatar
I called got it right from www.por15.com as there were no distributors around me. Is the frame going to be blasted/clean or rusty.
To be safe id use their mariene clean, metal ready, and then por 15.
Old Nov 21, 2007 | 06:44 AM
it will be wire wheeled to bare clean metal. is that a 3 step process? what is mariene clean? thanks
Old Nov 25, 2007 | 06:20 PM
SevenStars's Avatar
Its just a dirt/ grease remover. Check out the site it should answer your questions and their 1800 number is actually helpful
Old Nov 25, 2007 | 07:54 PM
kandied91z's Avatar
been using it for years, just used some last week on my gas tank. 10 hours really isn't enough time to base how long paint is going to keep from scratching but reguardless you should use the etching primer on the paint if you are painting bare surface that is truly clean. if you don't then let it cure much, much longer before you do that. typically at least 24 hours. it isn't a miracle paint that will restore your metal or keep it perfect forever. it does do what it promises though and lasts pretty well!
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
