Polished Depressurized hood struts pics....
Old Jan 22, 2007 | 11:32 AM
  #16
Angelis83LT's Avatar
Originally Posted by luckyou03
aren't the struts steel? and will soon rust first time it rains?
If you use a sealing polish they should not rust.. if anything you could put a clearcoat on them to keep them from rusting.. and make cleanup easy
Old Jan 22, 2007 | 01:01 PM
  #17
Bayer-Z28's Avatar
Where'd you get them! I want a set! Or can I just modify my stockers? You said you drilled them. I wonder if yo0u could start w/ a really small bit. OR I could get a set of shot stockers.
Old Jan 22, 2007 | 01:42 PM
  #18
Megalis's Avatar
You can use your stockers, or buy some crappy used ones if you like, either way. And yes you can use a smaller bit. As small as you want, but make sure the push pin you put in that small hole can with stand the weight of the hood and the force of somebody yanking it down by accident. If they yank it down with strong pins in there it will not go anywhere. If it gets pulled with weaker pins, you run a risk of the pins breaking, which really is no big deal anyway.
Old Jan 22, 2007 | 02:05 PM
  #19
Z28SORR's Avatar
Looks nice! I just removed mine and use a support rod in the front, like most of the new cars.
Old Jan 22, 2007 | 04:24 PM
  #20
Z95m6's Avatar
Can you post the part number of your original shocks so i can see if they're different from regular z28's. Thanks
Old Jan 22, 2007 | 07:42 PM
  #21
Bayer-Z28's Avatar
Sweet. I'm thinking of doing that. Just polish the stockers w/ 2000 grit, or have them dipped?
I'll clarify. I meant to use the TINY bit for relieving the pressure... ...come to think of it, that might send a small fast stream, like a pressure washer. I might not do that now...
Old Jan 22, 2007 | 07:55 PM
  #22
DustinZ28's Avatar
looks nice
Old Jan 22, 2007 | 08:29 PM
  #23
Megalis's Avatar
actually I did 220 then 400 and then 600 lastly, 1200 grit. hope that helps.
Old Jan 22, 2007 | 08:30 PM
  #24
Megalis's Avatar
Originally Posted by DustinZ28
looks nice
Thanks everyone for the comments
Old Jan 23, 2007 | 02:41 PM
  #25
Z28SORR's Avatar
Sorry did this over 20 yrs ago. Struts are long gone.
P.S. Sure doesn't seem like it's been that long!!
Old Jan 23, 2007 | 04:47 PM
  #26
Z95m6's Avatar
Oh ok i thought you removed them on your SS, thats my mistake. Sorry.
Old Jan 23, 2007 | 07:14 PM
  #27
Evil Lord Lucas's Avatar
Gonna definently do that. Do you think it would work for the rear hatch struts as well? Mine are completely shot.
Old Jan 23, 2007 | 11:57 PM
  #28
Megalis's Avatar
I don't see why it wouldn't , they are the same thing pretty much. But where to leave the pins while the hatch is closed??
It is not in the pic, but I have since attached a cool looking chain to each pin and looped it around the bottom of the strut. It looks decent and the pins are always there.
Old Jan 25, 2007 | 08:39 AM
  #29
I see how to take off the hood struts; but how do I remove the rear hatch struts?
Old Jan 25, 2007 | 05:06 PM
  #30
Megalis's Avatar
You know I never really looked and I don't know. ? I sure you can figure it out. Just probe around there
