Polished Depressurized hood struts pics....
Old Jan 20, 2007 | 06:13 PM
Megalis's Avatar
Finally had time to post pics of my depressurized polished hood struts. Both on and off the car Oh and I forgot to mention that I have an aftermarket hood, which is why I did it. It is fiberglass and it looked like it was starting to warp ever so slightly
http://camaropics.50megs.com/struts.htm
Old Jan 20, 2007 | 07:12 PM
Jun10rp's Avatar
looks good did u buy them like that or do it yourself
Old Jan 20, 2007 | 07:20 PM
Slappy3243's Avatar
This may be a stupid question, but what is the point of that? I think it would me much easier to just use the stock struts instead of having to stick those pins through them every time you want to have your hood open.
Old Jan 20, 2007 | 07:24 PM
Angelis83LT's Avatar
Perhaps, but then with that setup you never have to worry about the hood coming and smacking you in the back of the head because they loose preassure because of age. About the only good thing about the struts being preassurized is it makes it easier to open the hood.. My opinion. they should have stuck with the spring loaded type like on 2nd gens... never ever had a problem with those.. even after front end collision...
Oh and those things look pretty nice IMO.. Good job
Old Jan 20, 2007 | 10:51 PM
razor02097's Avatar
I could see someone doing that mod on the cheap if their struts failed. IMO I like the strut design its simpler but yeah it would eventually wear out.
Old Jan 20, 2007 | 10:56 PM
Megalis's Avatar
Actually I have an after market hood which I failed to mention, and the pressurized struts were starting to warp the hood ever so slightly
Old Jan 20, 2007 | 10:57 PM
Megalis's Avatar
yeah I did, took about 2hours for both. I keep polishing them every day until they turn almost chrome like
Old Jan 20, 2007 | 11:26 PM
slowdrive's Avatar
I did that also on my turd gen if you look close you can see the hair pins in the strut rods
Old Jan 21, 2007 | 04:07 AM
Z-RATED94's Avatar
Megalis, nice job and I understand your point on why it was needed. slowdrive,
Old Jan 21, 2007 | 08:41 AM
MAGIC Z's Avatar
i polished mine a few years ago i have a aftermarket hood never had any warping on my hood to this day
Old Jan 21, 2007 | 12:21 PM
Megalis's Avatar
Agreeded! That car is the furthest thing from "turdy" you can possibly get.
You're lucky.
I noticed that upon closing it, when you pulled it down to fast it would seem to flex a little to much. Also since it was going to the audio shop and I am getting a cam put in it shortly, everybody else is going to yank down on it like if it were OEM. Before something terrible happens I figured I needed to take care of it.
Old Jan 21, 2007 | 02:23 PM
IROC-T's Avatar
By the title and not seeing the pic, I thougt why not just take them off. After seeing the pic that's a great idea, gonna' try it on my 3rd gen I've hau three sets of struts on my hood and none lasted longer than a month, if that.
Is there a safty procedure when drilling?
Old Jan 21, 2007 | 05:59 PM
Megalis's Avatar
I would were goggles just to be on the safe side and drill slow, if you do that the air will come out little by little. You will also need to let all of the fluid inside drain out after drilling. I used a 3/8's bit by the way. good luck
Old Jan 21, 2007 | 09:22 PM
Z95m6's Avatar
Originally Posted by Megalis
You're lucky.
I agree they put way to much stress on the hood. When i first was test fitting my SS hood i was sure that my hood would break/crack if i kept the stock hood struts on with the hood. They just have way to much pressure to work with the light weight, weaker hood.
Old Jan 22, 2007 | 11:22 AM
luckyou03's Avatar
aren't the struts steel? and will soon rust first time it rains?
