Polish top of intake manifold?
Old May 26, 2003 | 02:20 AM
Sanger's Avatar
I was curious if there was a way to clean up the top of the intake manifold to get it looking cleaner. A friend of mine said he used a light sandpaper and it came out clean when he showed me. So I was wondering if sanding it, then polishing it would make it put out a little more shine??
Old May 26, 2003 | 02:32 AM
turbo_Z's Avatar
yes in order to polish that rough of a surface you will need to sand it.
Old May 26, 2003 | 08:31 AM
PoorMan's Avatar
I have a pic of a completely polished manifold if you want me to email it to you. It's awesome, but the shine will dull after awhile. I think it's better to only polish things that can be touched up after you put it back on the car. The fuel rails, throttle body, ect.
I did the common powercoat on mine with rail polish, ect. I have a couple pics in the link. Grime on polished parts looks alot worse than grime on paint. Billit polish and a rag is all that is needed on the fuel rails becasue it's already a smooth surface. The throttle body, ect require sanding first. 200, 400, 600, 800, 1200, polish. The more sanding before polish the better. Try to get the metal as smooth as the fuel rails before appling polish. Just my .02.
Jeff D.
Old May 26, 2003 | 10:06 AM
ROCKN SS's Avatar
http://www.netsnapshot.com/pcw/build...UNT=1058&KEY=4
Old May 26, 2003 | 11:18 AM
Brent94Z's Avatar
Super Moderator
I'll move this to the Appearance Section.
Could go in the shown and shine forum too but there are a number of guys in the Appearance Forum who know quite a bit about polishing parts.
Old May 26, 2003 | 11:44 AM
Mindgame's Avatar
Lots of work getting a nice polish cause you have to remove all the casting flash first. Then you'll need to seal it so it doesn't oxidize..... perhaps clear anodize or powdercoat.
-Mindgame
Noer
Feb 28, 2015 11:29 AM
alex5366
Feb 17, 2015 08:12 PM
CARiD
Jan 27, 2015 06:27 AM
Elcojoe
Nov 17, 2014 10:27 PM
Jul 4, 2005 05:00 PM
