Painting Brake Calipers?
Old Jul 18, 2004 | 04:48 PM
slayer6x6's Avatar
Question Painting Brake Calipers?
I want to paint the calipers on my T/A to go along with my new rotors. Is there any prep work I should do before I paint them, and what type of paint should I use? I want to paint them red.
Old Jul 18, 2004 | 05:04 PM
eagleknight97's Avatar
Re: Painting Brake Calipers?
Theres not much prep work involved. Just make sure you clean the area well with brake cleaner. If you buy a Caliper painting kit, they usually come with their own cleaner, use that if you buy the kit. You can go to almost any parts store, and they should have caliper paint. Ive also seen kits. As long as the paint is high temp, you should be good, but im not 100% sure.
Old Jul 18, 2004 | 06:46 PM
n2ceptor's Avatar
I used Engine paint.... Cleaned with brake cleaner, then soap and water.. You can smooth out the metal on the caliper, if you want to remove any burrs or pits...
Old Jul 19, 2004 | 02:22 PM
LT4Firehawk's Avatar
Don't use engine paint, I tried that and it doesn't look that good. Wal-mart just started carrying a Duplicolor brake caliper paint kit for $15 that includes everything you need including ceramic paint. I just bought this kit and will be redoing mine in the next week or so.
Old Jul 19, 2004 | 02:57 PM
slayer6x6's Avatar
Cool, thanks for the input guys.
Old Jul 25, 2004 | 05:02 PM
Onez4u2bn's Avatar
I have the Duplicolor kit sitting her infront of my face also, just picked it up. Would you guys paint front and back calipers or just front?
Old Sep 9, 2004 | 08:28 PM
jrtf83's Avatar
i painted all four on my v6, now i'm going to do the same on my SS.
Old Sep 9, 2004 | 08:38 PM
Pewter Z's Avatar
Obligatory Brent Link: http://www.bfranker.badz28.com/fbody/calipers.htm
Old Sep 9, 2004 | 11:05 PM
mvnatedog's Avatar
I don't mean to jack the thread, but does everyone here paint their calipers with them still attached to the car? I saw Brent did, and I'm wondering how hard it is to remove them, then paint them. Thanks, and sorry for any semi-thread-jacking...
Old Sep 9, 2004 | 11:15 PM
Ryatt-SS's Avatar
You would actually recieve the best results if the calipers were removed, thoroughly cleaned and then painted, however you will need to bleed the brakes when done.
As long as you clean the calipers real good and bag off the car, you will be just fine.
Old Sep 10, 2004 | 05:20 PM
Compstall's Avatar
Engine paint works fine. Use primer prior to application.
Alien
Jun 27, 2015 01:13 PM
May 1, 2015 01:14 PM
CGM2010CAMARO
Apr 7, 2015 07:44 PM
TransAm4utoenv
Aug 28, 2002 11:06 PM
