Painted LT1 alternator
Old Nov 17, 2004 | 11:48 AM
Myxtreme1's Avatar
Has anyone ever done this? I am interested in doing something bacause that thing is ugly. Might as well do it now while the car is torn apart.
Old Nov 17, 2004 | 11:53 AM
Geoff Chadwick's Avatar
Re: Painted LT1 alternator
Check my sig on the polishing guide Todd did. I've done my alternator, 58mm Throttle body, Acc Bracket, water pump, filler neck...
Honestly I think that polishing stuff turns out better. Dont know why. And believe it or not it's easier and cheaper then you'd think. I just spent $20 on wheels/rouge at Sears and another $15 in sandpaper and I'm good to go.
Also considering in order to paint it properly you should clean and sandblast it (or just sand) anyway to get a clean surface - might as well just polish it, IMHO. I have painted stuff before - but I'd rather polish for the look of it. Just beware - polishing is addictive.
Old Nov 17, 2004 | 12:34 PM
Myxtreme1's Avatar
Yeah I can do all that here at work. Is there a way to take the alternator apart so that I can just bring the housing and not the whole thing? Thanks!
Old Nov 17, 2004 | 12:45 PM
Z95m6's Avatar
There are pics in my sig. I painted mine aluminum. There is a before and after i painted some engine parts.
Old Nov 17, 2004 | 03:02 PM
Myxtreme1's Avatar
Nice! Did you take it apart to do it? What kind of paints did you use? Thanks!
Old Nov 17, 2004 | 05:37 PM
Z95m6's Avatar
Actually all i did was put a strip of masking tape around the center section where it's black. Then just clean, prep, and paint it. I just used a regular aluminum paint. You could probably use hi temp but just regular old paint worked for me.
Old Nov 19, 2004 | 07:54 AM
Myxtreme1's Avatar
Sounds good, I'll give it a try and let you know.
Old Nov 19, 2004 | 01:50 PM
v7guy's Avatar
I've done it and taken the whole thing apart, it's not too hard and I would def. recomend it just a little tough getting the brushes to stay compressed while you slide it into the housing, I would reccomend it.
HectorM52
Jun 23, 2016 08:42 PM
Gtpguy
Jan 26, 2015 04:50 PM
HectorM52
Jan 16, 2015 10:21 AM
ModdedNerd
Dec 14, 2014 10:28 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
