Painted interior instructions
Old Mar 7, 2006 | 04:53 PM
Z28 97's Avatar
Can some give complete instructions so i can make my interior look like this...what products?where to get them? and instructions!
Old Mar 7, 2006 | 05:09 PM
downwithmustang's Avatar
Re: Painted interior instructions
Cool look.
Old Mar 8, 2006 | 07:28 AM
93 Trans Am's Avatar
im doing mine with just primer and spraypaint.. ill post pics when my cam decides to start working again
p.s. how the hell do i take off my vents i wanna paint those 2
Old Mar 8, 2006 | 11:53 AM
Brangeta's Avatar
Pained vents look like crap, don't do that.
Old Mar 8, 2006 | 12:11 PM
mook99TA's Avatar
They make spray paint for vynl and plastic parts check our autozone or pepboys they should have it.
Old Mar 8, 2006 | 02:25 PM
Silvershark's Avatar
I would recommend vinyl paint by duplicolor. As long as you wash each item with dish soap and water and then let it air dry you will get great results. I am almost finished with the majority of my interior. I just need to clear 2 more times on a few parts and let them dry so I can install them.
Old Mar 8, 2006 | 11:33 PM
p.s. if u decide to do it the budget way like i did.. MAKE SURE to primer AND go over it with clear coat afterwards.. if u dont it will peel off like nothing.. if u do itll last for a long time
Old Mar 8, 2006 | 11:52 PM
and another p.s.s.
...be careful installing and uninstalling the gauge bezel.. its enough to make u turn emo.. im currently cutting my wrists and listening to fall out boy cuz i did it today
Old Mar 9, 2006 | 01:39 AM
I didnt primer because I thought this stuff didnt need to be primered... I think I am going to find out the hard way that you need to primer it..
Old Mar 9, 2006 | 02:32 PM
meissen's Avatar
I've painted without primer before and never had a problem with peeling. Problems with peeling sounds like it didn't adhere to the plastic well, it's not a result of the primer being used, it's a result of making sure the oil and toppers used on the plastic to make it shine (IE: Armorall, Meguiar's Natural Shine, etc) are gone and off so the paint sticks.
Old Mar 10, 2006 | 06:18 AM
meissen's Avatar
You could also use 3m adhesion promotor.
Old Mar 10, 2006 | 06:20 AM
Ryan 97 Ram Air T/A's Avatar
Prep with degreaser and scotchbright, alternating back and forth. All those tiny scratches on the surface are perfect for the paint to adhere to. I quarantee etching the surface will make the paint stick 100 times better. Windex would probably work if you're afraid of degreaser attacking the plastic.
Definitely use primer, then wetsand, color coat, wetsand, clearcoat, polish. Take your time and it will come out perfect even with cheap paint.
Old Mar 10, 2006 | 10:41 AM
Brangeta's Avatar
Wouldn't Dawn dishwashing soap work as a degreaser?
2000silverz28
Sep 7, 2002 01:48 AM
TheV6Bird
Aug 27, 2002 10:38 PM
BadBowtie93Z28
Aug 9, 2002 07:52 AM
TheV6Bird
10
Aug 2, 2002 08:00 PM
TheV6Bird
11
Jul 28, 2002 05:25 PM
