Painted Calipers
Old Dec 5, 2002 | 06:33 PM
KevinAce's Avatar
Painted Calipers
Hey,
What do you guys recommend as far as painted calipers go? The guys that put my wheels on through a quick splash of red "caliper" paint all over them (didn't disassemble them or mask anything off, just sprayed). There's some runniness and some spots missed. Is it best I just go over it with 3-4 layers of paint. Or sandblast the paint and stuff off, put some primer on, then paint?
I want to get the "cherry red" finish my car already is. Doesn't have to be too flashy, but a pure red none the less.
Thanks,
Kevin
Old Dec 5, 2002 | 10:00 PM
cndctrdj's Avatar
i used engine enamal. i took almost all of it apart and taped off the rest. i sprayed it let it dry drove it for about a week. wet sanded it then sprayed on a few more layers just to even it out and get the spots i missed. the paint will withstand 500 degrees and it doesn't look bad at all
Old Dec 5, 2002 | 11:47 PM
KevinAce's Avatar
Probably not the most fun taking it apart? How's the engine enamal finish? Does it look pretty clean, a pure color?
Old Dec 6, 2002 | 09:39 AM
pu12en12g's Avatar
I used enamel and high temp clear coats. The prep work is very important. Also the time between coats.
Lots of Pics in sig. (Page 2)
Old Dec 6, 2002 | 10:11 PM
cndctrdj's Avatar
the finish is pretty good not the greatest cause i didn't use any clear coat but it is just your brakes mine get covered with so much dust that i have to clean them at least twice a week. but yes the finish is good. i used the same paint ( for matching issues) on my side molding strip and soon to be on my trans am word. it doesn't look bad at all i will try to get some pics soon
Old Dec 7, 2002 | 12:54 AM
joed4640's Avatar
hey man i did them this summer
buy some brake caliper/engine spray paint and some clear coat, i just masked the area around the calipers and sprayed and make sure you have a paint brush to get the hard to reach areas. no need to take them apart
i put 4 coats of paint and 2 coats of clear, and you cant do this w/o the brake caliper declas from after thoughs auto, they really set them off there like $20
everyone asks if i have aftermarket brakes, they look awsome
GREEN3112
Feb 10, 2019 09:19 PM
football4life
Oct 4, 2015 07:48 AM
CARiD
Sep 30, 2015 05:44 AM
92_RS_305
Sep 8, 2015 07:47 PM
alphaauto
Jul 26, 2015 04:40 PM
