Need help removing the rear fender on 94 camaro
Old Mar 10, 2003 | 04:55 PM
andrew000l's Avatar
i need to remove the back passenger fender on my camaro since a recent wreck smashed it up. so im not real sure on what the best way to remove the is, any help is appreciated thanks.
andrew
Old Mar 10, 2003 | 06:30 PM
Smokinsometires's Avatar
Exclamation
That would be called the quarter panel not fender
That needs to be cut off. I would let a shop do that
Old Mar 10, 2003 | 07:17 PM
Matt97PTA's Avatar
agreed. if you look in the door jam you will see a seam where the pannels meet and are welded. if you look in the jam of the hatch and drop the bumper, ect. i take a profetional to do a job like that with some specific tools and materials. Sorry to say but i wouldnt even try if i were u.
Old Mar 10, 2003 | 10:40 PM
Whistler's Avatar
All around the rear quarter panels are seam-sealed spot welds. If you remove your hatch, roof panel, rear bumper and taillight panel, you will see the perimeter of it. Scrape off all the seam sealer and drill out all the spot welds.
After a little prying and cutting, it will come off. I made it sound WAY easier than it is, and if you attempt this without the proper equipment and skills, I would say you have an almost definite possibility of causing damage that will cost thousands to correct.
Old Mar 10, 2003 | 11:53 PM
Brent94Z's Avatar
Super Moderator
I do a ton of stuff on my car myself. However, removing the rear quarter panel is something that'll I'll let my body shop guy do for me
Patricklt1
Apr 24, 2015 06:29 AM
4586
Jan 3, 2015 07:22 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
Anderson
Jul 28, 2002 10:57 AM
